Router Jig - Planer/Jointer
Forum topic by Walnut_Weasel posted 08-04-2009 03:01 PM 7006 views 0 times favorited 6 replies Add to Favorites Watch
View Walnut_Weasel's profile
Walnut_Weasel
360 posts in 3096 days
08-04-2009 03:01 PM
Does anyone have any good plans/pictures/hyperlinks of jigs to easily use your router to joint/plane wide faces of boards? It is going to be a long time before I can afford either piece of equipment so I thought it may be time to break down and make a jig for my rounter.
-- James - www.walnutweasel.wordpress.com
View PurpLev's profile
PurpLev
8534 posts in 3522 days
#1 posted 08-04-2009 03:33 PM
for jointing with a router, search “router straight edge” or “straight edge” in general.
for planing you’d need some sort of rails and sled system. I did something similar in a larger scale here when I flattened my workbench you can do something similar, and on the same concept on a smaller scale for individual boards. basically have 2 rails that the board sits between them, and have a sled that the router is mounted to that rides on the rails. you’d need a flat bottom bit – and will need to clean this up later with a hand plane / sander though.
View Joe Lyddon's profile
Joe Lyddon
9979 posts in 3926 days
#2 posted 08-04-2009 05:35 PM
Yes, PurpLev’s method is very good for large areas…
For smaller pieces, the same approach can be taken, but easier…
Here are some ways that I have done it:
My first attempt using a simple jig:
http://www.ncwoodworker.net/pp/showgallery.php?cat=982
A different approach that works:
http://www.ncwoodworker.net/pp/showgallery.php?cat=1287
It can be done…
Jointing is simple… Straight edge, clamps, flush trim bit & you’re done.
View Kindlingmaker's profile
Kindlingmaker
2656 posts in 3400 days
#3 posted 08-04-2009 05:45 PM
http://lumberjocks.com/topics/1992 This is Gary’s
Walnut_Weasel
#4 posted 08-04-2009 08:53 PM
Thanks for the suggestions. I think I can incorperate a few of everyone’s jigs together into one super-jig! I particularly like Gary’s short cut for making two passes with your router and two backer boards to turn your planer into a jointer. Great stuff.
Now I just need to get time to make it…
If anyone else has ideas, please keep them coming!
Kindlingmaker
#5 posted 08-05-2009 03:51 PM
Walnut_Weasel, if you figure out how to get more shop time let us know ; )
Walnut_Weasel
#6 posted 08-05-2009 06:49 PM
That’s easy. All you need to do is hit the lottery!!
