Prefinish projects?
Forum topic by GarageWoodworks posted 114 days ago 260 views 0 times favorited 5 replies Add to Favorites Watch
View GarageWoodworks's profile
GarageWoodworks
210 posts in 520 days
114 days ago
I assembled my latest project (a blanket chest) yesturday and I contemplated prefinishing it before glue-up. This should make glue clean up a lot easier. I can see two potential problems with this: 1) finish will weaken any tenon shoulder glue adhesion (finish surrounding a mortise). 2) the act of clamping can scratch the preapplied finish. Take the poll:
online poll: http://garagewoodworks.com/gw_blog/
your thoughts?
-- Brian http://www.garagewoodworks.com
View kolwdwrkr's profile
kolwdwrkr
2249 posts in 487 days
114 days ago
Tape off all the joints needing glue then apply the finish. After the finish is dry remove the tape and tape off all inside corners where glue could squeeze out. To assemble with clamps use cork attached to cauls to protect the wood from damage. Finally snap some pics, download them, post them on LJs
GarageWoodworks
114 days ago
That’s not a bad idea. I’m going to try that next time. Thanks
GarageWoodworks
113 days ago
Come on Lumberjocks! 104 views and only 14 votes on my blog. Geesh. ;^)
View parkerdude's profile
parkerdude
40 posts in 348 days
113 days ago
Hi Brian,
I responded. I like to prefinish whenever i can. it’s much easier to sand and finish flat stock if the joinery isn’t to difficult. I just tape off the glue areas and finish away!
Good luck,
-- dust control
16928 posts in 474 days
112 days ago
Prefinish as Kolwdwrkr said
