Tuning the Bandsaw
Forum topic by Don posted 1052 days ago 1661 views 4 times favorited 14 replies Add to Favorites Watch
View Don's profile
Don
2590 posts in 1076 days
1052 days ago
This is an article that has been worked around a bit and was in a woodworking club newsletter that I used to edit. I’m sorry that I can’t recall the origin of this article, but there is as much of me in it as the original author. I’m being up-front in stating that although I’ve modified it considerably, it is not all my work. However, it contains a lot of useful information for those of you that are new to the bandsaw.
Have you ever notice how hard it is to rip a length of lumber on the bandsaw, especially a tall, thin piece (known as re-sawing)? You set the fence, previously aligned parallel to the miter slot. You set the width of the cut allowing a little extra for a pass over the jointer. Then you line up the wood against the fence and push.
And pretty much without exception, especially on a long cut, it will either crawl away from the fence or bind against it, causing the blade to deform sideways away from the fence.
The end result, in either case, is a tapered, irregularly shaped piece of work. This effect is usually exaggerated as you rip taller pieces. And it’s even more noticeable when you are ripping thin pieces, such as 18” veneer. It is usually devastating to your project, or else you cut extra thick to plane it true, wasting valuable timber.
This is a 100% common experience with bandsaws. The basic reason is that the blade is not parallel to the miter slot. Several factors are the cause, including blade tracking on the wheel, wheel alignment and blade tension. In the ideal world we would tune these out. In reality it’s very difficult, and won’t stay for long periods.
This inherent difficulty actually has a pretty easy ‘workaround’. The answer is “compensate”. Take a piece of 3/4” scrap at least 2’ long and about 4” wide with one clean, straight, and true edge. (Pass it over your jointer to achieve this.) Draw a line 1/4” from, and parallel to, the clean edge. Use a gauge if necessary, but the line must be parallel to the edge. Loosen the angle adjustment on the fence. You may have a factory fence that takes a wrench to set the fence angle. If not, you might want to build your own adjustable fence system.
The photos of mine below show one approach; this one also has a tall re-saw fence.
Slide the saw fence safely off to the left but keep it accessible. Start a freehand cut carefully guiding the timber through the blade along the line on the test board. Be smooth in your adjustments to follow the line. Don’t wander back and forth. In other words, don’t be swinging the board left and right to stay on the line. Make little corrections so that you ultimately establish a “cut path” before you run out of board. Cut slowly (at first) and continue until you get a cut that is tracking the line. About 3/4 of the way through the cut, or when you are sure you have established the track, holding the timber firmly, and turn off the saw.
DO NOT MOVE the piece. Clamp it to the table in this exact position (or hold it firmly). Slide the fence against the clean edge and tighten the angle adjustment.
With my shop-made table and fence this is easy. I simply loosen the front and rear knobs on the fence and adjust the angle of the fence to the wood. The front knob goes through a slotted hole that allows the fence to be adjusted at an angle. That’s the tracking angle for this blade, under this tension, at this particular time.
I was skeptical, especially when I could see the offset angle. But I then cut a 2mm slice off a 15mm piece of timber 1m long. Awesome! I never knew the saw could perform so well prior to understanding this.
You will have to do this setup prior to any bandsaw work if you have changed the blade, the blade tension, or the wheel alignment and it’s worthwhile checking the drift angle even if you haven’t. But the short time this takes is well worth the result.
Here’s a shot of the underside of my bandsaw that shows how the larger table was attached to my Jet 14” bandsaw.
This is the sail-track that I used in the table. [See my comments here on my drill press table for more details on this aluminum track.]
-- CanuckDon "I just love small wooden boxes!" http://www.hilsbiblechurch.org/
View frank's profile
frank
1503 posts in 1105 days
1052 days ago
Hi Don;
—-well its cold out today and next I’m heading to the barn to rip some wide pine boards. And yes its going to be way cold in there also which explains why I’m in taking a break.
Good article Don, I use my bandsaw often for re-sawing timbers and wood burls, so I am always playing and tuning it to keep that line true. This problem you have descibed here of ‘crawling away from’ or ‘leading into’ is what I also call bandsaw drift. You have described and worked out a very good solution to what can be descibed as you have so stated; a devastating and frustrating problem. Nothing like doing some bookmarking on a re-saw and finding out you have lost some good character of wood to ‘drift’.
I have also found that it helps to maintain a sharp blade. Ha! One thought comes to my mind now of when I first started using a bandsaw. I had a friend who told me that one of the first things I would do is spend time and wood just seeing how thin I could saw. Well he was right, of course he had already put the the idea into my head by then. Spent some time yes I did, just seeing how thin I was able to go, and so sliver thin it was. After all those years ago, I still have some of those slivers around which I always figure, yes one day I will use.
Thank you for taking the time to write a great article here.
Frank
-- --frank, NH, http://frank.wordpress.com/
View Obi's profile
Obi
2191 posts in 1136 days
1037 days ago
How much t-track did you end up buying?
-- http://ye-olde-cabinet-shoppe.com/
View Don's profile
Don
1037 days ago
8 meters = about 26’
View Don's profile
Don
920 days ago
After reading this post by Scott, I thought I would bump this post to the top in case there are others who don’t understand bandsaw drift.
View David's profile
David
1982 posts in 1038 days
920 days ago
Don -
Thanks for the important tip. I like your table and fence! I need to build something similar so this is great timing.
View scottb's profile
scottb
3402 posts in 1226 days
920 days ago
thanks for this one Don.
View Bob Babcock's profile
Bob Babcock
1808 posts in 985 days
920 days ago
Good timing…I get my 1st bandsaw tomorrow….Thanks Don
View Hawgnutz's profile
Hawgnutz
522 posts in 975 days
920 days ago
Thanks, Don. I just got my bandsaw out and tried some resawing, but the drift killed the cut. My Craftsman saw just don’t cut like the older ones! I wish, now, that I had paid some more and gotten a Rikon. Still, with the inspiration from your posting I think I can get it to slice like I want it to.
BTW, are you using the “sail track” in place of a T-track? Where do you get the sail track? Can you use a toilet bolt in them like you can in a t-track?
Thanks for the infomative posts!
God Bless,
Hawg
-- Saving barnwood from the scrapyards
View Don's profile
Don
919 days ago
Hawg, I live in Australia. There’s a aluminum extrusion supplier who, amongst many other profiles, supplies sail track for sailboats. I use standard coach bolts in this. Toilet bolts don’t fit.
However, sail track would not be my choice if purpose-made ‘T-track’ had been available at a reasonable price. The sail track does not have a flat profile on the top and the coach bolts slide in the track with a little resistance.
If you live in the USA or Canada, I recommend you source a purpose-made track – it’s superior.
View mot's profile
mot
4904 posts in 935 days
919 days ago
There is always an idea or two in an article like this that is really helpful. Thanks for posting it Don.
View USCJeff's profile
USCJeff
901 posts in 967 days
918 days ago
Good stuff. Check out Marc’s video at the Wood Whisperer site. It’s episode 13. He hits the basics as well as adds some personal preference to tuning up the saw. I found that when I got my first bandsaw last year, I had no idea where all the bearings and guides should be. Why do I need to have a dollar bill to set it up? I used it out of the box and didn’t love the tool. After properly tuning it, I don’t know how I get by without it.
-- Jeff, South Carolina
View Bryan's profile
Bryan
3 posts in 903 days
836 days ago
Super Don!! Maybe I won’t have to throw my band saw out after all.
-- Bryan
Dick, & Barb Cain
7045 posts in 1198 days
836 days ago
Nice table set up Don.
I missed this one the first time I guess. I’m glad it showed up again.
I haven’t had any drift with my new Rikon yet, But it usually does when the blade starts dulling. I think the fence is adjustable on mine.
View cajunpen's profile
cajunpen
5968 posts in 965 days
836 days ago
Thanks Don, I ran across a very similar “Tune-UP” article a month or so ago and tried it on my 14” Grizzly. Made a world of difference. I’m glad that Bryan & Dick commented on this article to bring it back to the front. I’m sure that there are a few LJs out there that will benefit from it.
