Best joint for hardwood carcass cabinet???
« back to Joinery forum
Forum topic by New2hardwood posted 04-27-2015 01:16 AM 1534 views 0 times favorited 11 replies Add to Favorites Watch
View New2hardwood's profile
New2hardwood
2 posts in 999 days
04-27-2015 01:16 AM
Hi All,
This is my first post!!!! I am am pretty junior to furniture making but managed to finish a 3-in-1 crib for my son (which led to the purchase of a Sawstop table saw among other power tools!!!)
Now I am wanting to make an armoire 60”h x 45”w x 25”d and have this on a box stand (with drawers).
My plan is to edge glue 1×6 boards (flatsawn S4S hard maple) to make each of the 4 sides. I realize that I should align the grain properly for all 4 sides! But I wanted to know what type of joint I should use at the corners? I live in Canada so we have winters of -40 celsius and summers to +34 celsius so changing humidity is the norm.
Are biscuits acceptable for wood movement, or should I be looking at doing some other joint to accommodate for expansion? I looked at my Collins book and the Joint Book but neither gave any good advice….
thanks,
Jared
11 replies so far
View skatefriday's profile
skatefriday
413 posts in 1355 days
#1 posted 04-27-2015 01:19 AM
Have you looked into using a nice cabinet grade hardwood plywood?
View Ghidrah's profile
Ghidrah
667 posts in 1095 days
#2 posted 04-27-2015 02:32 AM
I cut rabbits and dadoes for the carcass
-- I meant to do that!
View bondogaposis's profile
bondogaposis
4526 posts in 2224 days
#3 posted 04-27-2015 02:40 AM
If I get your concept right you aren’t going to need to worry about wood movement if you align the sides and top and bottom with the same grain orientation as it will all move in unison. Any number of joints could be used, rabbets, dovetails, box joints, splined miters, the list goes on. Biscuits would not be my choice.
-- Bondo Gaposis
View pintodeluxe's profile
pintodeluxe
5544 posts in 2686 days
#4 posted 04-27-2015 02:42 AM
I like dados for the fixed horizontal shelves. Rabbets for back panels work really well.
Biscuits work well to attach face frames to a plywood carcass.
17223 posts in 1729 days
#5 posted 04-27-2015 02:52 AM
Biscuits will work just fine. Where you’ll have to worry about wood movement is with the bottom and top.
View AlaskaGuy's profile
AlaskaGuy
3784 posts in 2182 days
#6 posted 04-27-2015 04:45 AM
I think you’re right on track using solid as opposed to plywood for this project. Solid wood makes much nicer furniture than plywood.
That being said I’d make the box using dovetails or box joint if you have the ability. Wood movement won’t be and issue because the grain will run the same direction around the box posing no cross grain situations even on the top and bottom. Take a look at this picture an note the dovetails and grain direction.
View jerryminer's profile
jerryminer
846 posts in 1314 days
#7 posted 04-27-2015 06:52 AM
If you’re building similar to the pic above (from AlaskaGuy)—then you should NOT glue the back together as a solid panel or you WILL have issues with wood movement (back will expand/contract across the width, but top and bottom won’t).
You can use T&G or shiplap or plywood, but not glued-up solid wood
AlaskaGuy
#8 posted 04-27-2015 11:39 AM
If you re building similar to the pic above (from AlaskaGuy)—then you should NOT glue the back together as a solid panel or you WILL have issues with wood movement (back will expand/contract across the width, but top and bottom won t).
- jerryminer
+1
I used a 1/4’’ piece of Plywood for the back. It sits against the wall and is full of drawers, you never see the plywood.
#9 posted 04-27-2015 12:32 PM
Ok, I was thinking of two sides, a back and front and then a top and bottom with grain running a different direction. If it’s like alaskaguy pictured then disregard my comment about bottom and top.
New2hardwood
2 posts in 999 days
#10 posted 04-27-2015 05:35 PM
Thanks for all the quick replies!!!!
Looks like I will do dovetails for joinery and rabbet in a frame-and-panel back (I did some reading and apparently it helps prevent racking?!?).
Looks like its time to buy a Leigh dovetail jig!!!!
Jared
View BinghamtonEd's profile
BinghamtonEd
2286 posts in 2242 days
#11 posted 04-27-2015 06:25 PM
Or a dovetail saw and some chisels, always an option. Not saying the jig won’t work as well, just a suggestion.
