Forum topic by FancyShoes | posted 04-27-2015 12:40 AM | 889 views | 0 times favorited | 10 replies | ![]() |
When using the jointer today the wood was vibrating slightly as i sent it across it. Trying to keep pressure down. Where do you want the pressure to be, and how much wood do i want to take off at a time? |
10 replies so far
#1 posted 04-27-2015 02:15 AM |
You should try to take off about 1/16 th of an inch. Also, jitter is possibly from the blades being too high. They should be about .001 to .002 over the outfeed table. Much higher will make the board jitter. You will not need too much pressure down if setup correctly. Pressure should be even. https://www.youtube.com/watch?v=M-ZZ0dhbJYY Brian -- Bigfoot tries to take pictures of me |
#2 posted 04-27-2015 02:30 AM |
You want more pressure over the outfeed side as soon as about a foot of your board is over it. In the beginning though, even pressure. Be careful not to tip the piece into the cutter head, especially with smaller pieces. -- Bill M. "People change, walnut doesn't" by Gene. |
#3 posted 04-27-2015 02:46 AM |
Good info above. Also, make sure you joint the board concave side down. This is true for face jointing and edge jointing. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#4 posted 04-27-2015 03:58 AM |
surely, is a knife blade issue. could be: -- The Carpenter Bee is derived from the Ancient Greek word wood-cutter |
#5 posted 04-27-2015 04:25 AM |
Pressure on outfeed after the head. Vibration may be caused by dull knives. Experiencing that at the moment on mine. -- Shooting down the walls of heartache. Bang bang. I am. The warrior. |
#6 posted 04-27-2015 04:30 AM |
Changing the belt to segmented one helps remove vibration. -- Troy | http://tf-workshop.com | The more I see nature, the more I am amazed at the Creator. - Louis Pasteur |
#7 posted 04-27-2015 12:34 PM |
Thanks for the advice! I will check out the youtube videos, and get the stuff to set it up properly as well as checking the blades |
#8 posted 04-27-2015 12:54 PM |
could be dull knives or the knife hone angle is incorrect. should be ~45 degree bevel, if this was reground to a different angle you are getting the heal of the angle hitting. In my experience this results in a smacking of the wood. #LoveYourJointer -- Don't blame me, I voted for no one. |
#9 posted 04-27-2015 01:13 PM |
Too deep of a cut and dull blades. -- Roger M, Aiken, SC |
#10 posted 04-30-2015 12:44 PM |
Once you make sure blades infeed and outfeed tables are set properly,think of passing the wood across the cutters as presenting the wood to the cutters.If you force down the wood your intended result will be skewed,same thing when edge jointing.It took me a while to get to that point,you will get there also. -- Kennyl |
Forum | Topics |
Woodworking Skill Share
12029 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6695 |
28058 |
CNC Woodworking
212 |
Hand Tools
5410 |
Jigs & Fixtures
1419 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4756 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
