carriage bolt w/ torque washer v. carriage bolt w/epoxy or J-B weld
Forum topic by WoodNSawdust posted 04-26-2015 10:03 PM 3372 views 0 times favorited 2 replies Add to Favorites Watch
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1146 days
04-26-2015 10:03 PM
Topic tags/keywords: question carriage bolt torque washer epoxy
Normally when I use a carriage bolt with wood I will use a torque washer.
Today I went looking for ones for 3/8” bolts and was shocked by the price. I have had problems with carriage bolts holding (not turning) with plywood or MDF.
I was wondering if I coated the square shoulders with either J-B weld or epoxy and tightened down the bolt would that hold?
2 replies so far
View JoeinGa's profile
JoeinGa
7735 posts in 1977 days
#1 posted 04-26-2015 11:47 PM
Whenever I want to use washers with carriage bolts I use a 3-sided file to make the round holes square in regular washers. Look for washers that “ALMOST” fit and you wont have much filing to do.
View Ghidrah's profile
Ghidrah
667 posts in 1192 days
#2 posted 04-27-2015 02:31 AM
Not sure I understand the issue, I’ve driven tons of carriage bolts over the yrs and never had this problem, and until this moment never knew about carriage bolt washers.
If I use a 5/8” carriage bolt I drill a 9/16” hole and hammer the bolt in. The threads and square imbed in the wood and the bolt does not turn when the nut is tightened.
-- I meant to do that!
