corian counter top
Forum topic by oakdust posted 117 days ago 440 views 0 times favorited 12 replies Add to Favorites Watch
View oakdust's profile
oakdust
158 posts in 714 days
117 days ago
I have a small piece of corian counter top that was left over from a sink cutout. I need to square it and use it as a recess for a cabinet. Can it be cut on the table saw and not chip it? Or is there a better way?
-- Bob, Rockford IL, http://www.woodandwax.net
View Greg Wurst's profile
Greg Wurst
716 posts in 731 days
117 days ago
Corian work very similar to wood, so as long as you use carbide-tipped blades you can cut it fine on the table saw. You can also route it just as easily. My wife turns Corian pieces into pens.
oakdust
117 days ago
Cool, Thanks Greg
View FEDSAWDAVE's profile
FEDSAWDAVE
321 posts in 330 days
116 days ago
oakdust…that would be Triple Chip saw blades for a virtual chip free cut.. Alternate bevel grind will leave a rough edge but it depends on what you’re using it for.
For the ultimate cuts in Solid Surface a MTCG (Modified Triple Chip Grind) is the best.
http://www.solidsurfacetooling.com
-- http://www.federalsaw.com
View Catspaw's profile
Catspaw
186 posts in 714 days
116 days ago
Use a 1/2” straight router bit and a straight edge.
BTW, that peice was left there in case you ever needed a repair to your countertop (assuming you have corian countertops.).
-- arborial reconfiguration specialist
oakdust
116 days ago
Thanks guys. I cut it on the table saw and then trimmed it with a flush trim router bit. Worked great
View John 's profile
John
110 posts in 300 days
116 days ago
If you have any left, make yourself a Insert for your tablesaw, they work great.
John
-- http://www.webshots.com/user/jahness
View BeeJay's profile
BeeJay
47 posts in 86 days
78 days ago
Also makes great runners for sleds etc. Keep it waxed and it runs lile water downhill.
-- I cut the damned thing twice and its still too short
oakdust
78 days ago
Sled runners, that’s a great idea
BeeJay
47 posts in 86 days
76 days ago
My son is a PRO cabinet maker and works with it and Granite a lot. He put me on to it a couple of years ago.
oakdust
76 days ago
Do the cabinet shops normally pitch the small pieces? I am gonna start hanging around the cabinet shops
View bruc101's profile (online now)
bruc101
134 posts in 440 days
76 days ago
oakdust
I’ve got knife makers, pen turners, turners, interior designers, etc visiting my shop often, needless to say I have no scrapes so I would think you could go to a fabrication shop and they would give you their small pieces. Wouldn’t hurt to ask.
bruc
-- "Give The Gift of Life, Adopt A Child"
View LesB's profile
LesB
555 posts in 341 days
76 days ago
All good advise but be sure to turn on your dust collector and wear a mask. The dust is like talcum powder and goes everywhere.
I have used larger pieces (12X18) to make cutting boards. Routing a “blood” groove around the edge and putting rubber feet on the bottom. Made great Xmas gifts one year for Xmas.
It works for table saw inserts but if you have a thin strip across to top of the blade opening like my Delta saw has it tends to break there. I also drilled and threaded holes to install headless screws in for fine tuning the level so it is flush with the top of the saw table.
-- Les B, Oregon
