Torsion box- Floating 8 Foot Shelf
Forum topic by MRod posted 115 days ago 516 views 0 times favorited 3 replies Add to Favorites Watch
View MRod's profile
MRod
69 posts in 960 days
115 days ago
Topic tags/keywords: torsion box floating shelf 8 foot long
Halo folks!!!
Okay so with advice from Marc the WW and the just go and get it done folks at woodweb (http://www.woodweb.com/knowledge_base/Floating_Bookshelves_Without_Brackets.html)
I slung up a floating bookshelf last night that is – get this – 8 FEET LONG and 11″ deep, 1.75″ thick.
All on a nice 8′ long cleat of oak and well see the pics for the rest.
I threw 8 1 lb clamps and a sander on top of it. seems a bit wobbly but in sturdy. DOES THAT MAKE SENSE?
I am banging on it and such and it seems sturdy, but I would think that if you grab any shelf hanging from toggle bolts (rated at 50 lbs) that it would wobble as a complete box…does that mean it is going to come flying out of the wall.
I am using those more advanced toggle bolts that allow you to take them in and out until you commit to your spot. I have bolts every 18″.
THIS IS A CUSTOMER PROJECT, therefore I will be uninstalling this soon and re-installing at the clients shop where they will put 30-40 1 lb coffee bag on it. It will be installed about 9′ from the ground into a 1/2″ drywall.
HMMMM – your thoughts? Am I going to get a call back here?
Thanks,
MRod
http://picasaweb.google.com/lh/photo/vnD_vWAxYDbzgFOHsN78BQ?authkey=Gv1sRgCIuLhKaQ4fCwTw&feat=directlink
Torsion box, before installation
-- MRod, Henderson, Colorado by way of Brooklyn!
View lew's profile
lew
4496 posts in 652 days
115 days ago
I would think it should hold providing the mounting bolts, for the cleat, are fastened into studs and not just toggle bolts into drywall.
View MRod's profile
MRod
115 days ago
That’s my problem. I am not sure what I will have behind the walls. I need to go over there and do a test, perhaps above the drop down ceiling to see what the customer truly has.
Thanks!
TopamaxSurvivor
3044 posts in 573 days
115 days ago
There should be a stud behing every one of those mud strips where they mudded the sheet rock screws.
