Forum topic by SG6578 | posted 04-26-2015 05:38 PM | 742 views | 0 times favorited | 5 replies | ![]() |
I started out with a walnut slab about 89” long x 15” wide 5/4. Cut it down to two pieces 40” x 15” to compensate for significant end checking that I found unrepairable. Will have them planed down until they clean up at another shop with a large planer. Both pieces have a triangle shaped crack that goes through the board and extends down the length approx 11”. Should I make a bowtie or consider another method? Would I be alright if I just epoxied the entire top? I plan on ripping a straight edge on both of them and joining them at the middle to make a table top for a coffee table. This is my first rodeo with live edge so I appreciate any advice you can muster up. Thanks, Kevin |
