Joinery question, workbench in progress...
Forum topic by ryno101 posted 08-03-2009 06:26 PM 1615 views 0 times favorited 8 replies Add to Favorites Watch
View ryno101's profile
ryno101
388 posts in 3662 days
08-03-2009 06:26 PM
Topic tags/keywords: question
When you need help, who do you call? The LumberJocks, of course!
So, here’s my dliemma. I’m building the base for my workbench, and want to be able to have it be disassembled if needed, and I very much want to avoid the use of carriage bolts, which would be an easy fix for what I’m trying to do.
The leg assemblies will be put together with mortise/tenon joints at the top and bottom, and will integrate a full-width top and foot, thereby eliminating the need for stretchers on the sides.
I’m using 4×4 (3 1/2” square) mahogany for the leg assemblies, and two 5/4 mahogany deck boards laminated together for the stringers.
My idea was to use a single dovetail that would be mortised into the leg assembly, to provide a lateral lock against racking from side to side, but I can’t glue it in if I want to be able to take it apart in the future, so I’ll need something to keep it flush with the leg once it’s assembled.
My initial thought was to use a cross brace running lengthwise on the legs, but that looked awful when I drew it up. Here’s my second thought:
The 1” dowel would go through the leg and dovetail, and be locked in place front to back with the pins…
Is this the best way to approach this? Is there a good alternative?
-- Ryno http://shawsheenwoodworks.com
8 replies so far
View PurpLev's profile
PurpLev
8535 posts in 3646 days
#1 posted 08-03-2009 06:48 PM
Ryan, take a look at this 21st Century Bench by Rob Bois (a fellow LJ) he has 2 stretchers between the legs, the top one is similar to your design, but instead of pins – he’s using bolts which might be an easier solution.
just make sure you leave enough of the leg material and not compromise it’s strength. looks good though!
View sIKE's profile
sIKE
1271 posts in 3752 days
#2 posted 08-03-2009 08:16 PM
I don’t know if this has been tried, but you might be able to do 2 drawbores (each) all the way though the leg and dovetail. When you wanted to disassemble you would just knock them back out.
Take a look at the Woodworking Magazine’s blog, it has a lot of information about drawboring as well as Schwarz’s Workbenches book….
ryno101
#3 posted 08-03-2009 08:57 PM
sIKE, wouldn’t a drawbore be impossible due to the shape of the joint?
View kolwdwrkr's profile
kolwdwrkr
2821 posts in 3588 days
#4 posted 08-03-2009 10:09 PM
Bentlys is the way I would go
View sIKE's profile
sIKE
#5 posted 08-03-2009 10:32 PM
Why would you think that? As DaveR said taper the pin and you wouldnt use as much of an offset with this kind of joint as you would with classic M&T joints….but then again as the almighty Schwarz (may it be with you) says the offset should only be 1/16th to 3/32nd off of the Mortises hole…
ryno101
#6 posted 08-03-2009 10:56 PM
Thanks… DaveR, my intent with the dovetail was to resist that loosening, I figured that the legs would be inclined to splay out from the center over time, loosening the joint. I figured that the dovetail would be the best joint to resist that movement. The pins are not going to be resisting against the loosening of the joint, they’d be simply a way to ensure that the dovetail doesn’t pop out.
PurpLev
#7 posted 08-03-2009 11:20 PM
Dave brought up a very good point that I had completely didn’t even think about when I first read this post.
Out of curiosity Ryan: why are you against carriage bolts? I find that the use of those gives a nice clean joint that can be taken apart, or tightened up in the future as the need arise. Other than that – bentlyj presented joint would be just as good, without having to use metal hardware.
TopamaxSurvivor
18270 posts in 3674 days
#8 posted 08-04-2009 01:00 AM
You could put a little taper on the dovetail front to back so it would pull flush as it seats.
