Tapering 3 inch legs
Forum topic by Brian posted 08-03-2009 02:31 PM 1120 views 0 times favorited 8 replies Add to Favorites Watch
View Brian's profile
Brian
79 posts in 3677 days
08-03-2009 02:31 PM
Any suggestions on how to taper 3” thick legs?
I usually use a taper jig but this time the legs and jig would be higher that the TS blade.
TIA for any and all replies.
-- http://www.brianpenning.com/
8 replies so far
16274 posts in 4184 days
#1 posted 08-03-2009 03:07 PM
The only other thought that comes to mind is to do it on a bandsaw. You could possibly either draw the taper lines out and make the cuts freehand, or make a jig of some sort.
teenagewoodworker
2727 posts in 3734 days
#2 posted 08-03-2009 03:18 PM
bandsaw and a handplane is probably the best way to do it in your situation
View coloradoclimber's profile
coloradoclimber
548 posts in 4033 days
#3 posted 08-03-2009 03:30 PM
Brian, Another option might be to use a jointer. Sounds like a lot of wood to remove but the jointer would be wide enough. I remember reading an article in FWW (here’s link1 and link2 but both require a paid subscription, maybe you can find a copy). Google tapering using a jointer and you should come up with some descriptions. Here’s one quick example.
View Gary's profile
Gary
9324 posts in 3398 days
#4 posted 08-03-2009 03:32 PM
I use the jointer. Cut a wedge for the leg to ride on as it passes over the blade. It takes some practice.
117063 posts in 3543 days
#5 posted 08-03-2009 04:04 PM
make a sled or jig for you table saw or band saw
View Dan Lyke's profile
Dan Lyke
1519 posts in 4091 days
#6 posted 08-03-2009 07:09 PM
You could probably set up a jig for a planer, too, not just a jointer.
Might take most of the stock off with a cut on either side on the tablesaw and then clean-up mismatch with the jointer or planer.
View BeachedBones's profile
BeachedBones
201 posts in 3368 days
#7 posted 08-03-2009 10:10 PM
I’m with a1Jim, 3” should be possible with a 10” blade. Maybe revisit your taper jig design. A simple wedge jig that rides along the rip fence. Or could make the jig a fixed angle that could be flipped with the leg to the left side of the blade to finish the cut.
-- You know.... I think that old wood needs to be furniture.
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3551 days
#8 posted 08-03-2009 10:28 PM
When I do tapers, I use this method, on the side touching the fence I apply a large headed screw or bolt.Then I unscrew this out to match the taper and simly run it through.You need to keep the bolt nearest to yourself before running it through so that you get a good long run before it wanders away from the fence.You could also hot melt glue a short or longer tapered piece of wood nearest to the fence that works too.have fun Alistair
