tounge and grove question
Forum topic by fredf posted 1391 days ago 678 views 0 times favorited 4 replies Add to Favorites Watch
View fredf's profile
fredf
495 posts in 1882 days
1391 days ago
I am going to edge a piece of 3/4” plywood with a 1×4. I am trying to figure out if it would be stronger to have the tongue on the plywood or the groove. or doesn’t it make much difference??? I can cut the 1×4 on the router table, but not sure if I can handle a good sized chunk of plywood (finished panels to be 39×78) on the table. I think I might be better off cutting hand held (I have a over sized base to keep the router from tilting—but it only fits my smaller router so I might be better off with the grove in the plywood)
any thoughts??
fred
-- Fred, Springfield, Ma
View ajosephg's profile
ajosephg
1723 posts in 1733 days
#1 posted 1391 days ago
I’d put the groove in the plywood so as to not have problems chipping the veneer.
-- Joe
87364 posts in 1749 days
#2 posted 1391 days ago
I usually put the tongue on the banding by putting the tongue on first and then cutting to width.
View TomHintz's profile
TomHintz
207 posts in 1570 days
#3 posted 1391 days ago
I would just put a work support to either side of the router table and cut the groove in the plywood there. 78” isn’t small but with simple supports to help out you shojldn’t have any problems on the router table.
-- Tom Hintz, www.newwoodworker.com
View LesB's profile
LesB
901 posts in 1615 days
#4 posted 1390 days ago
I go with Jim. Put the tongue on the 1 X 4. You can use a guide clamped on the plywood to guide the router as you cut the grove in the edge. I would use a slot cutting router bit with a bearing and have the bearing ride on the clamped on guide.
Another alternative is to use biscuits for alignment and support.
-- Les B, Oregon
