Rikon 10-325 and 220V
Forum topic by weldoman posted 04-25-2015 06:53 PM 925 views 0 times favorited 7 replies Add to Favorites Watch
View weldoman's profile
weldoman
114 posts in 2087 days
04-25-2015 06:53 PM
Any of you guys with the 325 wire it for 220v and could you tell the difference from 110v. Thanks Dave
-- missouri, dave
7 replies so far
View knotscott's profile
knotscott
8057 posts in 3405 days
#1 posted 04-25-2015 06:56 PM
It really depends on the particular 110v circuit, and the amp draw of the 10-325. Some 110v circuits are better than others. If your 110v circuit is ideal, you may not notice much difference, but if you’re 110v circuit is causing voltage loss, it could be very noticeable. Are you currently have troubles with your 325 on the current circuit?
weldoman
#2 posted 04-25-2015 07:16 PM
No problems Scott, never tripped a breaker, I stalled the saw once but that was resawing with a dull blade. Just curious because I gave up on used and ordered a 2nd 10-325 from Sears today, Think I’ll try this one on 220v just to see.
-- missouri, dave
18358 posts in 1886 days
#3 posted 04-25-2015 07:18 PM
I guess that grizzly didn’t work out for ya? I thought I might have seen it on CL after you got it.
View MrUnix's profile
MrUnix
6773 posts in 2228 days
#4 posted 04-25-2015 07:22 PM
The only real advantage you get on 240v is the ability to run smaller wire to the machine and maybe a slightly cooler running motor depending on how it’s wound. There is no difference in power between 240v and 120v. A 1HP motor will be a 1HP motor regardless of input voltage.
PS: As Scott mentioned, if you are pushing the limit of your 120v circuit, then going to 240v would be a better choice.. usually when you start getting over 1.5HP or so.
weldoman
#5 posted 04-25-2015 08:03 PM
Yea Bill, I didn’t care for the Grizzly 18”. I got all the bugs worked out of it and cleaned it up, looked like a new saw. I guess being 15 years old it lacked alot of the newer options I like on the Rikon. I put in on CL and sold it within a week, actually made a little on it.
Thanks for the info Brad.
-- missouri, dave
knotscott
#6 posted 04-25-2015 08:21 PM
No problems Scott, never tripped a breaker, I stalled the saw once but that was resawing with a dull blade. Just curious because I gave up on used and ordered a 2nd 10-325 from Sears today, Think I ll try this one on 220v just to see.
- weldoman
If you’ve got 220v readily available, it can’t hurt to make the switch. You might notice a difference, you might not, but the circuit should be less likely to cause voltage loss and the excessive heat associated with it.
View toolie's profile
toolie
2135 posts in 2658 days
#7 posted 04-26-2015 11:43 AM
No additional power will result switching to 220v. Perhaps faster start up, but no additional hp.
