In the market for a Bandsaw -- Opinions?
Forum topic by woodtablet posted 04-25-2015 04:23 AM 1778 views 0 times favorited 27 replies Add to Favorites Watch
View woodtablet's profile
woodtablet
30 posts in 1144 days
04-25-2015 04:23 AM
Topic tags/keywords: question
I am looking to buy a new bandsaw, and before I started searching the internet, my initial limit was 700, but now I am willing to borrow some additional funds and stretch that maybe 900.
I was looking at the Grizzly Anniversary 14” or maybe even the 17” ?
http://grizzly.com/products/14-Deluxe-Bandsaw-Anniversary-Edition/G0555LANV
http://grizzly.com/products/17-2-HP-Bandsaw-Anniversary-Edition/G0513ANV
I live in America, so it feels a little weird to make such a large purchase and have it shipped to my house without ever seeing one. I was thinking of going with the 14” and the riser block. To date, the largest thing I have had to resaw was 8”, and did it on my tablesaw, which was sad, because I I lost sooo much material when trying to get 3×1/2” pieces out of 7/4” stock. I mostly work with maple (hard & soft) and cherry, but plan on doing resawing of walnut as well. Again up to about 8”.
Is a 14” with a 1HP motor enough ?
Anyone else have suggestions for bandsaws in my price range (or close to it ?)
I went to a industrial supply store, and they were trying to sell me the Laguna 14×12, but after reading about bad customer service here on LJ, I am not eager to do that.
I have been reading here on the forums, but many of the post are from a few years ago, so I wanted to ask it again.
Thanks Everyone,
-Woodtablet
27 replies so far
View CoachSchroeder's profile
CoachSchroeder
97 posts in 1509 days
#1 posted 04-25-2015 05:06 AM
I had the exact same experience as you.
Grizzly stood out because of their price point.
Talked to a local retailer who pushed me to the Laguna. Seeing the machine and being able to test the rigidity of the frame and guides was pretty impressive.
Wish I could compare directly to a grizzly machine.
-- -Sam, in Wisconsin
View TDH's profile
TDH
15 posts in 1256 days
#2 posted 04-25-2015 07:55 AM
I have a Grizzly G0555LANV and can’t say enough good things about it. If you are going to be re-sawing a lot of hard woods I would go with the G0513 even the next size up in hp. With the bigger saws you can use bigger blades (3/4 and up), this makes a big difference in re-sawing hardwoods, wider boards and cutting your own boards to set up to dry. I have cut a lot of hardwoods on my G0555LANV with a 1/2 inch blade it’s just a little slower than my bigger saws. As with any saw the set up and blade is the key, use good sharp blades and keep saw tuned.
View pauljuilleret's profile
pauljuilleret
100 posts in 1557 days
#3 posted 04-25-2015 09:21 AM
quite some time ago laguna did have an issue with their customer service as I have been told on the flip side of that I have owned the 14/12 for a little over a year now and do not regret at all buying it on my opinion the ceramic guides coupled with the almost 14” re-saw capacity are worth the extra cost over the griz. not knocking the Griz I came real close to driving to PA to get one before I ran across the laguna good luck on your choice both are good machines from what I hear.
View MC's profile
MC
201 posts in 2252 days
#4 posted 04-25-2015 09:50 AM
I have a Jet 14” band saw that I picked up used with very little use. Runs great. Check the local ads there are a lot of good deals out there.
View dhazelton's profile
dhazelton
2687 posts in 2201 days
#5 posted 04-25-2015 11:19 AM
If you’re looking at a 14 inch then look for an older Delta and add the riser block and save some money.
View Jim Finn's profile
Jim Finn
2619 posts in 2827 days
#6 posted 04-25-2015 01:36 PM
I have the GO555 saw with a riser. It has a one HP motor and re-saw fence. I bought it just to re-saw with and it does a fine job on anything I can fit under the 12 1/2” thickness capacity. I use a 1/2” carbide “SUpercut” re-saw blade now, after, trying others. In my experience re-sawing is all in blade choice. I have used this saw daily since 2008.
View AZWoody's profile
AZWoody
1263 posts in 1129 days
#7 posted 04-25-2015 02:43 PM
I have the 17” anniversary and so far love it. If it’s between those 2, get the 17”. You’re paying not much more for a larger machine but also a better body frame design. I can also tell you the 17” has 2 4” dust collection ports. One at the bottom and one right under the table.
Laguna has a strong reputation for bandsaws so I would definitely take a look but reviews, like you mentioned, on their customer service has been horrendous. I live an hour from the local city, but 2-5 hours from actual dealers so for me, phone support is extremely important and Grizzly has always been top notch, the very few times I have needed them.
I use mine right now for mainly cutting large slabs down the middle so I can flatten them easier. Right now I have the Grizzly blade they recommended for resawing which cuts through it like butter but I am going to get a Resaw King blade this week for resawing much thicker stock.
I also ended up getting an older 18” Grizzly for $200 off craigslist but the design on the 17” is better for resawing so I’ll keep a narrow blade on that one and use it for curves and also for cutting tenons.
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1081 days
#8 posted 04-25-2015 05:19 PM
I have the Grizzly G0513X2BF and love it. The foot break imho is useless, but the motor break is great! The X2 adds the cast iron wheels so you get a much smoother cut.
View rwe2156's profile
rwe2156
2797 posts in 1385 days
#9 posted 04-25-2015 06:18 PM
I don’t know about cs, but the Laguna 14” bandsaw is an awesome saw. A friend of mine has one and it is pretty sweet.
I always go bigger than I think I need. If it’s in the budget i would go 17”.
If you do a lot of detail work you can do what I did – pick up a deal on CL.
I picked up a Jet 12” cheap and keep a 1/4” blade on it for little stuff,
The 18” I keep a resaw blade on.
View fuigb's profile
fuigb
466 posts in 2862 days
#10 posted 04-25-2015 07:45 PM
I love my Jet 14” Pro, 13” resaw capability and guts enough for serious cutting (for me, a hobbyist) including neighbors’ trees that i plank into short boards. Stickers around a grand but I caught the 15% off sale. It helped a bunch that. I was sitting on a grand in credit card reward points. So, I recommend the Jet. But if you don’t have the points then a good used one might do. Good luck.
-- - Crud. Go tell your mother that I need a Band-aid.
View Rayne's profile
Rayne
734 posts in 1444 days
#11 posted 04-25-2015 08:37 PM
I have the Porter Cable 14” you can get from Lowes and also bought the riser kit. Well worth the upgrade, IMO. It’s my first BS so I don’t have much experience with it beyond what I’ve used it for and it works great as long as you have a decent blade and have tuned it up properly. Mine doesn’t drift much anymore after I tuned it like Alex from Carter Products recommended. I also agree with you that I’d rather see the tool before I buy it, especially of that scale.
View WhyMe's profile
WhyMe
979 posts in 1466 days
#12 posted 04-25-2015 08:43 PM
Rikon 10-325
View bbasiaga's profile
bbasiaga
1119 posts in 1900 days
#13 posted 04-25-2015 08:47 PM
I’ve got the ShopFox W1706 14” band saw. It is similar to the lower end grizzly’s but has cast iron wheels instead of aluminum ones, and an enclosed base. I think I paid $600 for it. If there is a local shop that has one, that might be a better option than the Grizzly. It wasn’t much more money, and had some upgrades. It has been good to me. I have been thinking of the riser kit, but haven’t gotten there yet.
-Brian
View ElChe's profile
ElChe
630 posts in 1241 days
#14 posted 04-25-2015 11:02 PM
If your max budget is 900 then I’d go with the 14” because you will need some money for goodies like a couple of nice blades. I have the Griz G0513X2 and my only regret is not getting the motor brake. The CI wheels take forever to spin down.
woodtablet
#15 posted 04-26-2015 08:53 AM
Wow alot of great information here !
Its good to know that others have had the same concerns as well. This gives me more to ponder.
Thanks everyone!
-Woodtablet
