How to drill a really long hole in deep wood.
Forum topic by mmh posted 1388 days ago 16941 views 0 times favorited 21 replies Add to Favorites Watch
View mmh's profile
mmh
3034 posts in 1890 days
1388 days ago
Topic tags/keywords: drill deep hole drilling into long wood crotchwood drilling into cross grain wood
Got your attention? Great! I have a very unconventional task and would appreciate your expertise.
Q: How can I insert a 1/4” metal rod inside a 36” cane shaft?
The project is a cane shaft made from crotchwood Claro Black Walnut. Yes, crosswood of 36” long, grains going all directions but lengthwise. The shaft is 7/8” at the bottom diameter, increasing to 1 1/4”- 1 1/2” oblong diameter.
I have a 12” drill bit, and one thought is to cut the shaft at 22” length, drill into the bottom piece – bottom end upwards, middle section downwards and the top piece – middle section upwards as far as possible, (and re-attach pieces) but the diverse direction of grain can make the bit travel off center, not to mention the roundness of the shaft is hard to clamp down.
Another thought is to rout out a 1/4” strip along one side of the shaft to insert the rod, then fill gap with wood. This will cause an unsightly strip of different grain, but the task would be complete. Again, the shaft is shaped so there are no straight (non-rounded) edges to clamp down.
Saturating the shaft with thin CA glue has come to mind but is not as secure as a metal rod to take the weight of a 200+ lb. person. The 1/4” metal rod w/ epoxy seems to be the most adequate method I can think of (short of not using crotchwood to begin with).
Laminating two pieces of crotchwood with longrain hardwood will be another experiment, but meanwhile I’d like to figure out this task.
I could use a lathe with a lathe chuck and a center rest to hold the shaft in place in order to drill sideways. The lathe is only 34” long, but I could cut the shaft to 22”L as stated earlier if this option would work.
So, now you have the problem. Got any legitimate answers?
21 replies so far
View SCOTSMAN's profile
SCOTSMAN
4309 posts in 1753 days
#1 posted 1388 days ago
You could seperate it right up the middle with a fine tooth blade such as a bandsaw metal blade .Taking extreme care to keep it central.Then route the both sections with a ball nose bit large enough to take your metal rod then glue it back around the rod.Not perfect but this is a dificult job to get perfect by any means the only other option which is the recognized option is to mount it in a lathe and long hole bore it like you do for a standard lamp but with a piece this thing you need to be careful you dont drill out through the side it can be done with patience though actually this is the correct way to do it.Alistair
View Russel's profile
Russel
2199 posts in 2107 days
#2 posted 1388 days ago
A most insteresing problem. I might try to slice the whole thing in half and route a cove in each then glue it back together.
View pommy's profile
pommy
1695 posts in 1859 days
#3 posted 1388 days ago
MMH i take it have not made the cane yet so if it was me i.d router the slot for the metal bar in to two blocks and epoxy two peices together the grai difference would be so small you would hardly know
just my two pence worth
Andy
-- cut it saw it scrap it SKPE: ANDREW.CARTER69
View John Ormsby's profile
John Ormsby
1235 posts in 1905 days
#4 posted 1388 days ago
set the cane on a lathe and drill at least half way through. Then turn it around and drill the other half. Your holes will come out much in line with each other and more centered. You will need a lathe that has a hole in the headstock. Make sure you buy a drill bit long enough to take in account the headstock, chuck and final depth of material. You can use a 1/4” drill bit that is used in the alarm or cable installation business.
-- Oldworld, Fair Oaks, Ca
View lew's profile
lew
8980 posts in 1923 days
#5 posted 1388 days ago
Meilie,
How big is your lathe? They make some really long drill bits for the electrical industry. Maybe you could get a hollow tail stock center and use a long bit to go thru the center of the stock. I am just not sure how you could keep it from tracking off center as you get further into the wood.
Lew
edit: just saw the lathe length, sorry
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
SCOTSMAN
#6 posted 1388 days ago
if you go down the drilling on the lathe then remove the drill and clean it every few seconds or it will build up swarf and wander .This will work ok I have done it many times the sell a long bore drill just for this for making holes in wood for lamps and standard lamps.Good luck practice on apiece of scrap if you wish first take courage and go for it working slowly it is doable very much so.Alistair
87102 posts in 1745 days
#7 posted 1388 days ago
Johns got it handled
View John Gray's profile
John Gray
2366 posts in 2053 days
#8 posted 1388 days ago
a1Jim said it!
34370 posts in 2568 days
#9 posted 1388 days ago
I like John’s idea of drilling through the head stock into the blank and then turning the blank around and go at it again.
SCOTSMAN
#10 posted 1388 days ago
I don’t get that if you come from the tailstock towards the headstock and reach the headstock there is surely no need to turn it round as your there already. you need to drill through the tailstock which must be hollow and work halfway and then turn it around not throught the headstock surely??? Alistair
TopamaxSurvivor
13192 posts in 1844 days
#11 posted 1388 days ago
I have deep drilled for a Kentucky rifle ramrod a couple of times. I soft soldered a drill rod on to a drill bit. With the open part of the ramrod channel inletted (about 24”) to use as a guide, the drill went straight through the 16-18” of solid curly maple right in front of the trigger guard. It’s easier than it sounds. If you use the lathe method above, it should be easier yet.
View HoBoMoNK's profile
HoBoMoNK
1381 posts in 2296 days
#12 posted 1388 days ago
Here’s an extra long drill bit that I use to drill out holes for rustic lamps:
Lee Valley
I would cut my cane stock in to three equal pieces, drill each piece, then assemble the pieces on the rod.
I’d use spacer washers made from a contrasting wood.
Glue it all together, then shape the shaft in you favorite way.
-- 温故知新
John Ormsby
#13 posted 1388 days ago
The reason to drill a bit past the middle and then turn the stock around is to insure better accuracy and less possibility of the bit to wander off center. It is very easy for a bit to wander with varying degrees of hardness, grain angle, etc. Wood is wood and one must respect and deal the nature of the material.
View Broda's profile
Broda
313 posts in 1687 days
#14 posted 1388 days ago
what if you could do it the same way they make digeridoos?
drill in as far as you can then push a very hot rod through the middle?
-- BRODY. NSW AUSTRALIA -arguments with turnings are rarely productive-
View Kindlingmaker's profile
Kindlingmaker
2646 posts in 1694 days
#15 posted 1388 days ago
HF has really long drill bits, 24” to 36”. ...but… I would take a steel rod and sharpen the end into a drilling point then slowly bore through the entire cane and once through cut off the rod ends and leave it in place. (I always do things the hard way.)
