shaper purchase
Forum topic by dustycajun posted 04-25-2015 01:23 AM 620 views 0 times favorited 9 replies Add to Favorites Watch
View dustycajun's profile
dustycajun
71 posts in 1450 days
04-25-2015 01:23 AM
Looking at purchasing shaper grizzly g1035 from a cabinet shop thats closing he has two he wants to sell both wants 300 a piece. Dont know if i need both. Any suggestions
Thanks
-- klcrd
9 replies so far
View TheFridge's profile
TheFridge
9249 posts in 1451 days
#1 posted 04-25-2015 01:42 AM
300 isn’t bad. Maybe both if you plan on doing a lot of raised panel doors.
dustycajun
#2 posted 04-25-2015 01:48 AM
He has one set for rails one for stiles and used a router for the raised panel. Seems like it should be the other way round
-- klcrd
dustycajun
#3 posted 04-25-2015 05:29 PM
Is it really that tedious to change from stile to rail cutters
-- klcrd
View cabmaker's profile
cabmaker
1720 posts in 2774 days
#4 posted 04-25-2015 05:34 PM
Dusty…...that’s a 1.5 hp machine with a very small top. If u could get the pair for that price then it might be a deal. Don’t know for sure but a 1/2 inch spindle is probably the max on that machine. Certainly more capable than a router table …....but an entry level model for sure ! If you really have need for a shaper you will out grow that one in a few minutes.
jb
cabmaker
#5 posted 04-25-2015 05:38 PM
Is it tedious…..well depends on your cutting tools. If your using a grizz set they are matched up nicely like the early delta sets. For cope and stick you simply remove one set then drop the other on. No spindle height or fence depth change will be neccessary. Very efficient
cabmaker
#6 posted 04-25-2015 05:40 PM
You will however need a reversible capability, that is if you don’t wish to change spindle height
dustycajun
#7 posted 04-25-2015 05:46 PM
Thanks. There is a extra table extension which makes it larger. I also have a couple routers i coyld set up in too
-- klcrd
cabmaker
#8 posted 04-25-2015 05:51 PM
Dusty you can also lay a 3/4 inch slab on top to gain whatever size surface u desire . On that one however the under nut capacity will greatly be affected. For little more than cope and stick it will get u buy especially if your mostly cutting face down
dustycajun
#9 posted 04-25-2015 10:25 PM
Thanks for the replies. I want to get more into cabinet doors so far i have only s couple small routers i want to expand my abilities with cabinet doors
-- klcrd
