| Forum topic by daltxguy | posted 1386 days ago | 24159 views | 81 times favorited | 329 replies | ![]() |
1386 days ago |
Topic tags/keywords: sketchup plugin cutlist layout cutlistplus resource tip The CutList 4.1 sketchup plugin helps you determine how much of each material you need to produce your design, taking into account nominal sized lumber with allowances for finishing to final size. Then it goes one further and lays out all of the pieces on boards or sheet good sizes of your choosing. The discussion of this plugin has long lived in my original blog ( where you will still find lots of useful information) but it has grown to where it should live in its own forum. If you want a copy you can download v4.1.5 here Note: The Cutlist plugin has been tested to run with Sketchup 6, Sketchup 7 and Sketchup 8. If you have any questions, comments, suggestions, please post them here and I or someone who can help will respond asap. I am the current author/maintainer of the plugin and am committed to making it as bug free and useful as possible. It has enjoyed quite a bit of scrutiny from the woodworking community, and, as a community we have made it a very popular and useful plugin. There have been nearly 22,000 downloads of the plugin to date since the revamped v4.0. first released July, 2008. I’ll be posting ‘the best of’ the blog and other tips/hints here from time to time. -- If you can't joint it, bead it! |
329 replies so far
#1 posted 1386 days ago |
Most awesomeness! Your plug-ins all grown up and get its own fourm! -- //FC - Round Rock, TX - "Experience is what you get just after you need it" |
#2 posted 1386 days ago |
Q. Is it easy to add multiple units? A. There’s no way to multiply the number of units through the plugin, but if you cut and paste a second copy of your model and select it for the plugin, then it would lay out all of the pieces from both. -- If you can't joint it, bead it! |
#3 posted 1386 days ago |
Thanks for setting this up. A great plugin and one that I have used to help me build (in the process right now) my bathroom vanity. -- "Checking for square? what madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2 |
#4 posted 1363 days ago |
I have problem importing cvs into CutListPlus. When the names of the parts or materials have non english names they are not recognized properly in CutListPlus, but are okay in CutList. !http://img26.imageshack.us/i/26471606.jpg/(http://img26.imageshack.us/i/26471606.jpg/)!:http://img26.imageshack.us/i/26471606.jpg/ -- M.A.N. |
#5 posted 1363 days ago |
I checked already and CutListPlus recognized cyrillic names properly. The problem is with cvs from CutList. I had to disable ”.” as a separation symbol in the ruby code to use ”;” instead. I’m trying to adapt SketchUP for furniture design and here in East Europe things are different – we are using mainly MDF, MDF profiles, aluminum profiles and melamine faced boards. Profiles are charged per lineal meters not cubic meters and there is no way to set banding, different sheet goods sizes and profile sizes in CutList. -- M.A.N. |
#6 posted 1363 days ago |
Thanks, but this is easy in CutListPlus – the problem is with the export of the cvs into the program. I need to use the same names of the materials, hardware and joinery as my suppliers to be easy to order. -- M.A.N. |
#7 posted 1362 days ago |
Hi dedov, Thanks for the feedback. I have made some changes to Cutlist to accommodate language issues already in the past. The following rules are applied for cvs files: If the sketchup language is british or american english, then the cvs separation character is ’,’ Note that I made these changes to accommodate sketchup decisions on what to display and to make it easier to import the cvs file. I key the decision on the language selected in sketchup. As for the part name, I merely take what it received from Sketchup and write it to the file with no modifications. Now, having said that. I feel your pain. There are improvements which can still be made which are more sensitive to the needs of CutListPlus specifically. I did not have a licensed copy of CutListPlus, only a very old version when some of the changes were made and I was flying ‘blind’ as it were. I rely on people like you to point out inconsistencies to make improvements. I am happy to hear your suggestions and to incorporate them into the next version and have you as the guinea pig to try out a beta version in the meantime. Contact me via PM using the LJ site and we can discuss what changes are required. Now the other thing which I might add to reassure you a bit is that I have recently made contact with Todd Peterson, who is the author/owner of CutListPlus and he has provided me with a license for CutListPlus and I have arranged to have a closer cooperation with him to make sure CutList keep up to the capabilities of CutListPlus. I am aware that the two tools are being used together and I can see why it is useful to do so and I hope to sort out any issue which you may have which might be under my control. The last thing which is important to know is that i make no money off of Cutlist or my work on collaborating with CutListPlus. I do it in my spare time because I believe strongly that technology should help to save some wood if possible. Your comment about including linear metres is loud and clear. I had intended to put an option in the next version which would then list in both metres and cu.m. Feel free to contact me and we can discuss further the changes which you would like to see. Steve -- If you can't joint it, bead it! |
#8 posted 1362 days ago |
Hi daltxguy, -- M.A.N. |
#9 posted 1358 days ago |
You may have answered this in previous posts, but has the problem with displaying the layout using Safari on a Mac been solved, other than using SVG output then opening the file in Firefox? I’m sorry is this is an old question. -- Tim, New York |
#10 posted 1357 days ago |
Hi formerflyer/Tim. Thanks for your question. I’ve answered your question below along with some related questions that may arise from my answer. Q. Does the Cutlist plugin layout work with Mac with the Safari browser? Q.Will the layout in a web browser window be fixed for a Mac? Q. Can I select the browser to use for Sketchup? -- If you can't joint it, bead it! |
#11 posted 1356 days ago |
Steve, Thank you so much for your reply. The plug-in is excellent even with this glitch. I go the route of generating the .svg file then opening with Firefox or Safari (both seem to open the file O.K.) then print it out from there. Your work surely saves all of us a great deal of effort. It is greatly appreciated. Tim -- Tim, New York |
#12 posted 1356 days ago |
Thanks for the link. I downloaded the file and I will install it in a few days. -- Whether You Think You Can or You Think You Can't, YOU ARE RIGHT!!! |
#13 posted 1355 days ago |
Thanks for your comments formerflyer(Tim) and Innovator Another idea that has been suggested by several people is to generate the layout inside the sketchup model putting the actual parts inside the board/sheet and creating a view. This is something I’d really like to try but it’s going to take some work, so feel free to encourage me if you think this is a good option, but also be patient! -- If you can't joint it, bead it! |
#14 posted 1355 days ago |
#15 posted 1355 days ago |
Hi dedov, No offense taken. My apologies for not getting back to the discussion yet. Your comments covered a lot of ground and I haven’t had a chance to get through it yet to see what might be changed as a result. I was away for several days on business. I promise I will comment in greater detail within a few days. -- If you can't joint it, bead it! |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3542 |
15751 |
Hand Tools
2028 |
Jigs & Fixtures
494 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
