Contractor Saw motor shutdown shutter
Forum topic by Scott C. posted 04-23-2015 11:58 PM 721 views 0 times favorited 3 replies Add to Favorites Watch
View Scott C.'s profile
Scott C.
158 posts in 2049 days
04-23-2015 11:58 PM
My Ridgid TS3650 is experiencing some shuttering/jerking when the motor shuts down. It hops a little on start up, but it’s much more noticeable on shut down. When it gets towards the end of shutting down it jumps a bit a makes a pretty audible ca-chunk, if a zero clearance insert is being used you can here the blade make a nice wang sound. If I take the belt off it seems to be fine. It still passes a nickel test though and otherwise runs and cuts fine. Arbor bearing, maybe?
Any advice?
-- measure twice, cut once, swear and start over.
3 replies so far
View knotscott's profile
knotscott
8013 posts in 3373 days
#1 posted 04-24-2015 01:05 AM
Just to eliminate variables, have you tried a different blade? Check that the pulley alignment is good too. You could also consider a different belt before resorting to new bearings.
Scott C.
#2 posted 04-24-2015 01:42 AM
Tried different blades, happens with all of them. I should have added, the motor mount is bent, but I have the motor shimmed to make the pulleys coplaner and aligned.
View pjones46's profile
pjones46
1001 posts in 2641 days
#3 posted 04-24-2015 03:27 AM
IMO the problem is the motor mount.
-- Respectfully, Paul
