5" orbital sanders
Forum topic by Deano56 posted 04-22-2015 11:56 PM 1475 views 0 times favorited 23 replies Add to Favorites Watch
View Deano56's profile
Deano56
91 posts in 1160 days
04-22-2015 11:56 PM
I’m tired of hearing my compressor kick on and off using my pneumatic 5” orbital sander. Which sander do you guys prefer? I saw that the Dewalt got the number one rating from one place, I didn’t like the feel of the Dewalt and actually like the Makita feel
-- Deano
23 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2657 days
#1 posted 04-23-2015 12:25 AM
I have a DeWalt ROS and it is not 1/10 the tool my Dynabrade pneumatic sander is. I’ll never go back to electric ROS. Maybe upgrade your compressor? Put it on the other side of a wall so you don’t have to listen to it? Mine would drive me crazy if it were in the shop with me!
View Ghidrah's profile
Ghidrah
667 posts in 1189 days
#2 posted 04-23-2015 12:29 AM
I’ve had the same PC 6” ROS since 92. I had to replace the hook-N-loop disk a couple yrs back, it still gets regular use. I don’t know what to say about the new PC products but in my experience the older ones were built to last
-- I meant to do that!
View OSU55's profile
OSU55
1632 posts in 1957 days
#3 posted 04-23-2015 12:40 AM
I’ve had the DEWALT D26453K 5” var speed model for ~ 5 yrs. Other than having to fix the VS dial, it’s been great. One reason I got this model is it connects directly to my shop vac, no add on connector needed. Almost no dust gets away. If the Makita fits your dust collection, I’m sure it would be a good choice.
The electric sanders won’t do the heavy sanding an air model will. It depends on how you use a sander. I handplane or scrape all surfaces, so I only use the ROS for light duty stuff. On a few occasions I’ve used it for heavier material removal and it is slow compared to air.
Ghidrah
#4 posted 04-23-2015 01:03 AM
I’ve also used my PC on metal, I also have a grinder for heavy metal removal. In both cases I prefer the electric versions unless you have a 50gal. 3 or 4 stage compressor the air can’t keep up with the electric tools.
View nakmuay's profile
nakmuay
79 posts in 1320 days
#5 posted 04-23-2015 01:10 AM
A slightly cheaper option than a new compressor would be to fit a large holding tank in the line. The larger volume would stablize the system and mean that the compressor would have to kick in less frequently. You can use any old gas storage tank. The pressure would be sitting way less than actual storage capacity.
View Joel_B's profile
Joel_B
341 posts in 1348 days
#6 posted 04-23-2015 01:42 AM
I recently bought a Bosch, forget what model # but it was about $60.
It has a nice dust collection system that works well with or without a vacuum.
I am pretty happy with it.
-- Joel, Encinitas, CA
Deano56
#7 posted 04-23-2015 01:45 AM
I have a DeWalt ROS and it is not 1/10 the tool my Dynabrade pneumatic sander is. I ll never go back to electric ROS. Maybe upgrade your compressor? Put it on the other side of a wall so you don t have to listen to it? Mine would drive me crazy if it were in the shop with me!
- gfadvm
i just cant see paying electric for 15 amp motor when I can run a 3 amp
-- Deano
gfadvm
#8 posted 04-23-2015 02:03 AM
Deano, I see your point but my hands ache for days after using my DeWalt. The Dynabrade is much easier on my ageing hands, has much better dust collection (with Abranet discs), and just works for me. Best of luck in your quest.
View crank49's profile
crank49
4030 posts in 2938 days
#9 posted 04-23-2015 03:18 AM
Well, I don’t own one, and likely never will, but Festool sanders get awfully good reviews.
Next notch down in cost would likely be a larger air storage tank. That would reduce the frequency of compressor starts.
The sander I use is a Ridgid 5”. Been working well for 4 years and I really like how it hooks up to my shop vac. Don’t like the position or design of the on/off switch. Hard to switch with my arthritic hands. Why can’t they just stick to the nice simple toggle switch they used to have.
View ,'s profile
2387 posts in 3514 days
#10 posted 04-23-2015 04:08 AM
I have owned milwaukee, dewalt, ridgid and dynabrades. The dynabrade is far superior. From an economical standpoint with our cabinet shop, the dynabrade makes us money and in the long run is more cost effective then the electric sanders. The sanders provide better results faster and is unmatched by the electric sanders. We have experienced electric and DA sanders for full time work for quite a long time since we do this for a living and electric just does not compare.
I will say when I first got into DA, I bought one from HF to try out and it sucked bad. So not all DA sanders are equal by any means.
In our case it helps that our AC is located in a lean to outside of the shop.
Deano56
#11 posted 04-23-2015 11:17 AM
my Souix 5” da is great, nice to hang on to, fairly quiet too. I could use a bigger compressor but, other things are ahead of that if I even really consider it. A larger tank will only drain slower before start up, the pump barely keeps up with the sander, so it would actually run longer filling up the tank. It’s a old 3hp Quincy with a 60 gallon tank, great compressor that still pumps up to specs, just not big enough for continuous running air tools.
-- Deano
View paxorion's profile
paxorion
1107 posts in 2013 days
#12 posted 04-23-2015 02:31 PM
I have Dewalt and Bosch 5” sanders that I reviewed earlier. For the price point, I have a strong preference for the Dewalt. Not sure if the higher end Bosch ones will give me a different opinion.
-- paxorion
View Gene Howe's profile
Gene Howe
10367 posts in 3396 days
#13 posted 04-23-2015 03:00 PM
I use a PC, Makita, De Walt and Rigid. (Hate changing paper…and, no I don’t have a router for each bit (-:> )
Why all different brands, you ask. All but the Rigid were picked up at sales/auctions.
I much prefer using the Rigid, regardless of the grit. It’s quieter, has less vibration and seems more aggressive.
The dust collection systems on ANY of my sanders are all POSs. I refuse to hook up my screaming shopvac.
I was given a pneumatic sander and haven’t used it yet. Not sure I want to. Might get spoiled.
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1542 days
#14 posted 04-23-2015 03:33 PM
I would go with nakmuay’s idea. if you want electric I have the new B&D and it’s fine for what it’s asked to do.
View ChipByrd's profile
ChipByrd
146 posts in 1894 days
#15 posted 04-23-2015 03:51 PM
