Rehydrating a plane tote
« back to Hand Tools forum
Forum topic by skcj213 posted 04-22-2015 07:00 PM 927 views 0 times favorited 8 replies Add to Favorites Watch
View skcj213's profile
skcj213
28 posts in 1461 days
04-22-2015 07:00 PM
Ok all of you vintage plane experts. Last fall my loving wife obtained a Type 11 Stanley Bailey #5 for me at an auction for $1. The only thing wrong, other than needing a good cleaning, was the rosewood tote was broke into 2 pieces and mounting rod bent. I am assuming it was dropped. I was able to straighten the rod, but the tote may be beyond repair.
As luck would have it, she found another #5 at an auction last week, paid $5 this time. This one was very rusty with the iron being severely pitted, but the tote was in one piece, unfortunately it isn’t rosewood. I typed this one to a 16, I believe, 1946-1947, the tote had a black finish on it that is almost completely chipped off.
My question is about how to rehydrate the tote? It is extremely dry to the point that I believe it would likely break if I tried to use it.
FWIW, I am going to try to epoxy the rosewood tote back together to see if I can salvage it as well.
Thanks in advance for any words of wisdom.
8 replies so far
View bandit571's profile
bandit571
19975 posts in 2680 days
#1 posted 04-22-2015 07:18 PM
Haven’t run into THAT problem on any of mine..you might try an overnight soak in Boiled Linseed Oil, aka BLO. Or just keep appling coats until it stops soaking in. Then buff with a wax.
Might check with Eric @ nhplaneparts.com. He runs a”parts store” on Ebay. IF he doesn’t have what you want IN stock, he usually can get too. Fast shipper,BTW
skcj213
#2 posted 04-22-2015 07:31 PM
Thanks for the comment bandit. I have seen several for sale on ebay for $20-$30. Honestly, a #5 is not worth much more than that from what I can tell. I downloaded a pattern to make one off of Leighvalley.com. If I can’t revive this one I will likely take a crack a making a replacement.
View chrisstef's profile
chrisstef
17381 posts in 3003 days
#3 posted 04-22-2015 07:47 PM
Before you lay epoxy on the broken tote, drill a handful of baby holes into it so the epoxy has something to “grab” to. Ive epoxied plenty back together and they’ve all held up just fine so far.
Id go with BLO as stated by the bandit.
skcj213
#4 posted 04-22-2015 11:02 PM
Chrisstef, thanks for the tip. I’ll do that.
View OSU55's profile
OSU55
1667 posts in 1986 days
#5 posted 04-23-2015 12:46 AM
If you like the standard Stanley tote design, then use the dwgs from LV. I have some redesigns here using the LV dwgs if you’re interested in a thicker, larger tote.
View Combo Prof's profile
Combo Prof
3504 posts in 1274 days
#6 posted 04-23-2015 01:14 AM
For what is worth I have repaired all my totes, handles and knobs using titebond II and so far have had no trouble. Sometimes I cut the broken tote so that has nice clean faces and sandwich a piece of mahogany or (rosewood if I have it) in between the two halves.
-- Don K, (Houghton, Michigan .. Soon Holland, Michigan)
View TheFridge's profile
TheFridge
9453 posts in 1482 days
#7 posted 04-23-2015 01:25 AM
Wenge, mahogany, walnut. That’s what I’ve repaired mine with. I kinda like my frankentotes. Tb2 or 3 has work fine for me too.
skcj213
#8 posted 04-24-2015 02:12 AM
Thanks all for your responses. I think I will try to repair the original and revive the second. Never hurts to have a spare.
