"Burning a hole"?
Forum topic by lilliputianfrivolity posted 121 days ago 385 views 0 times favorited 9 replies Add to Favorites Watch
View lilliputianfrivolity's profile
6 posts in 236 days
121 days ago
I’m stumped
I just started reading “The Workbench Book” by Scott Landis and on page 38 there is an excerpt from a Shaker Elder’s diary – ”...jan 15 worked out the big hole for the screw & bored the 4 holes for bolts & burned them out with a hot iron.” Now in this instance the boring is done and then the “burning” occurs, but I have previously heard of burning a hole without boring a hole first. I can’t recall exactly where I read this but I do remember it pertained to making a pipe. This passage really irked me though, because it reminded me of when I searched through the internet for an explanation on “burning a hole” but found none. I ended up using a complex jig, breaking the drill bit, buying a new one, breaking the pipe, making a new one and making my own gimlet to the length and thickness I couldn’t buy.
Regardless, how does one burn a hole in wood?
And just for curiosity’s sake, why did the Shaker Elder burn out the holes? They were for a vise or bench hook on a shaker style workbench. I am guessing it either added strength, decreased friction, or it was an easy way to enlarge the hole to an exact diameter.
Please placate my frustration friends.
TopamaxSurvivor
3044 posts in 573 days
121 days ago
I don’t know, but my guess is to enlarge the hole biggger than the bit he had. That is the problem with reading accounts of things that happened a century or more ago; so much was common knowledge they didn’t bother to explaing things we have never heard of. If I were going to burn a hole, I’d use a pointed iron that was red hot, keep putting it back in the forge just as if I were working the iron.
View Radoje's profile
Radoje
2 posts in 121 days
121 days ago
In boatbuilding school the explained to us about burning a hole for drifts that would hold the various keel timbers together. If you didn’t have a bit the right size for the drifts (or treenails) you were using you could make a “burner” that was just a piece of rod with the head hammered out to the diameter you needed and use it to sort of scrape out the hole to the right size with a brace (or a drill in these modern days). Not sure if this is the same thing the ol’ Shaker fellow was talking about, but there you go.
Radoje
View BeachedBones's profile
BeachedBones
187 posts in 299 days
120 days ago
I was reading a book in which they were making crude spears, once shaped they burnt the points to harden them. I wonder if this might have been done to harden the wood to be more resistant to the wear from the bolts?
-- You know.... I think that old wood needs to be furniture.
View firecaster's profile
firecaster
482 posts in 316 days
119 days ago
I once read a description of building stagecoaches. I don’t know why I was reading it but it talked about burning the holes. It made the wood around the hole harder and less likely to crack or break with the stresses of bouncing down unpaved roads.
-- Father of two sons. Both Eagle Scouts.
View TiffanyJeanne's profile
TiffanyJeanne
60 posts in 120 days
118 days ago
I’ve heard the same thing. Burning the hole adds strength. I do a lot of wood-burning for fun, and I can tell you that the heated and burned wooden areas of a piece, become slick, hard, glossy, and super-strong, compared to the un-burned wood around it. Perhaps that was the intention back then? To strengthen the hole to avoid any splintering or stripping? IDK… just a guess! lol
-- Tiffany Jeanne Balk ~ Labor, Live, Love, Learn, Repeat.
TopamaxSurvivor
118 days ago
I saw the Woodwright demonstrate buring in handles for chiels. I assumed it was just easier than trying to inlet the perfect tapered hole, but maybe it is to add strenght too.
BTW, welcome aboard Tiffany J!! :-))
View drgoodwood's profile
drgoodwood
387 posts in 1025 days
118 days ago
I drill and burn holes as part of my Appalachian-style of woodworking.
Burning smoothes the endgrain fuzziness in a hole and helps make it harder.
When I make hiking sticks, I always burn the hole through which I insert a leather wrist strap.
It helps to prevent chaffing and wear on the leather.
We also use burning to make a round hole square.
-- Randy, Rustic Artisan, a family tradition. (No PM's - auto-deleted.) - "I am a seeker, not a follower."
View woodpeckerbill's profile
woodpeckerbill
42 posts in 171 days
118 days ago
Listen to T.J. and the dr. the purpose of burning a hole (bored hole) is to add strength,prevent cracks and splits, and to smooth the surface of the hole and the area around the hole. Bill
6 posts in 236 days
116 days ago
Thank you all so much. This has certainly cleared up the situation somewhat. As soon as I find a need to use one of these techniques (or if I ever find myself with nothing to do) I will do some tests.
