Poly over paper
Forum topic by HD_woodchuck posted 122 days ago 249 views 0 times favorited 9 replies Add to Favorites Watch
View HD_woodchuck's profile
HD_woodchuck
30 posts in 186 days
122 days ago
Topic tags/keywords: question
Ok, so I recently built a game board which I wanted to place a printed logo (sports team, etc) on the game board and then poly over it. Problem is, as soon as I began to brush on the poly, the paper began to bubble and lift. I then tried to smooth it out and changed to spray poly. Over night the paper bubbled more, and the poly hardened. Now the surface that is supposed to be ‘glass’ smooth, has ripples from the paper.
I even used spray adhesive on the paper before placing it on the sanded wood surface.
Any suggestions?
-- "The German is like a willow. No matter which way you bend him, he will always take root again." - Alexander Solzhenitsyn -
View BeachedBones's profile
BeachedBones
187 posts in 300 days
122 days ago
You could try one of those plastic laminating kits on the paper first, see if that works for you, or at least keep it water tight for the poly to go over.
-- You know.... I think that old wood needs to be furniture.
View Ben Kahmann's profile
Ben Kahmann
232 posts in 170 days
121 days ago
Did you let the adhesive dry before applying the poly?
-- Ben Kahmann Dayton, OH
View Russel's profile
Russel
2063 posts in 837 days
121 days ago
I’ve tried that in the past and had the same results. I recently bought some “decal” paper and gave it a try and I really like the way it works and looks. I got it from DecalPaper.com.
View briancarter's profile
briancarter
1 post in 126 days
121 days ago
have you tried decoupage glue , it worked for me when i made a pen useing stamps
————————————————————————————Brian—————————————————-
TopamaxSurvivor
3063 posts in 574 days
121 days ago
I wanted do that making a target a few weekes a go, but I’ve had enough experience with paper doing targets, I was pretty sure that would happen. I didn’t have time to experiment, but I think I will try a spray laquer over the paper before I use the poly.
View CessnaPilotBarry's profile
CessnaPilotBarry
1288 posts in 601 days
121 days ago
Spray shellac on the paper will act as a barrier coat.
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
View cwdance1's profile
cwdance1
186 posts in 157 days
121 days ago
I have never tried this but everything I have read says you should use Shellac, everything is supose to go over it with out any problems.
TopamaxSurvivor
121 days ago
What will poly do over laquer?
Todd A. Clippinger
5653 posts in 998 days
121 days ago
I am guessing that the solvents in the poly was enough to loosen the glue. This is a similar effect to guys using contact cement for veneer and then the finish acts as a release for the same reason, it acts as a solvent to the adhesive and causes it to let go.
