best product/fluid to restore wood
Forum topic by ccpanel posted 07-28-2009 07:22 PM 1019 views 0 times favorited 4 replies Add to Favorites Watch
View ccpanel's profile
ccpanel
28 posts in 3268 days
07-28-2009 07:22 PM
I have an old axe handle that has dried out in the nevada sun and i want to save it-what oil or wax or??? can i put on it to keep it from cracking more and/or to lessen brittleness.
no-im not going to use it to cut firewood…. =)
i also have an old camper w/wood frame. the REAL 2×6 resting on the metal frame of the truck has dried out and i need to add some lubrication to it.
not a big deal-its out of the weather BUT… because it has dried out since installation in 1955-yes you read that right- it SQUEAKS liek CRAZY when driving. bolts have been tightened but it comes down to needing som sort of lube to add to wood to soak in.
i was thinking somthing like linseed oil or olive oil… thoughts?
View LesB's profile
LesB
1725 posts in 3438 days
#1 posted 07-28-2009 08:16 PM
For the axe handle you could use linseed oil, tung oil, or Watco danish oil (you have color choices on the last one)
For the camper you might try a mineral oil if you are looking for a lubricating affect (baby oil is the same thing and often cheaper). Most of the other oils will dry out and not lubricate.
-- Les B, Oregon
ccpanel
#2 posted 07-28-2009 09:21 PM
exactly the type of informed answer i was looking for.
not concerned at all w/looks.
will the mineral oil add the moisture back into the wood. im VERY concerned about not damaging the camper wood long-term. we intend to retire with this in 30 years… =) still being enjoyed now.
1955 chevy camper
View ZachM's profile
ZachM
83 posts in 3701 days
#3 posted 07-28-2009 09:28 PM
your picture link doesn’t work.
ccpanel
#4 posted 07-29-2009 06:10 PM
http://4.bp.blogspot.com/_Ok8GzUd9n14/Sgzu4BL1JCI/AAAAAAAAAac/n1lZxKTjXJc/s1600/DSC_9214.JPG
looks like it is working now.
there should be a picture embedded in posting also.
