How to turn basswood plates?
Forum topic by magicman posted 121 days ago 171 views 0 times favorited 2 replies Add to Favorites Watch
View magicman's profile
magicman
48 posts in 505 days
121 days ago
Topic tags/keywords: turn turning basswood basswood plates plates blanks
I am a chip carver and would like to turn my own plates. I have looked all over and can not find out how. I found books on how to turn regular plates, but nothing like the basswood blanks that I buy. Can someone “turn” me in the right direction. Ha Ha Ha. (sorry, coming off a 12 hour shift)
-- Twenty years from now you will be more disappointed by the things that you didin't do then by the ones you did. - Mark Twain
View lew's profile
lew
4494 posts in 652 days
121 days ago
Here is a site that has a lot of projects and tutorials. Maybe it will have something you need.
http://www.woodturningonline.com/
View LesB's profile
LesB
551 posts in 339 days
121 days ago
Basswood may present a problem turning because it is so soft but with sharp tools with some sanding it should work. Mounting it on a lathe might also be a problem because of the softness. You will need to use a plywood blank and a base and glue the bass wood to it with a piece of newspaper between the two pieces of wood so it can be separated after turning. The newspaper tears apart when you use a wide chisel to separate the pieces. Then just sand off the remaining newspaper and glue. Other softer woods that will work are cotton wood, alder, clear pine.
Here is one web site that that sells basswood: www.carpediemstore.com/viewItem.asp?idProduct=2650 They had 2” x 8” X 24” pieces that should work for plates. If you need wider pieces you may have to glue two pieces together.
-- Les B, Oregon
