Nova 3000
« back to Woodturning forum
Forum topic by GCIMark posted 04-21-2015 01:37 AM 1579 views 0 times favorited 31 replies Add to Favorites Watch
View GCIMark's profile
GCIMark
108 posts in 1308 days
04-21-2015 01:37 AM
I am an intermediate turner with an entry level lathe. I am looking to upgrade and have found a guy on Craigslist that has a Nova 3000 that he describes as being in “like new condition”. Says he inherited it from a guy that died shortly after purchasing it. “Turned a few projects and never got in to turning” and therefore wants to sell it. It has a regular tool rest and also includes an outboard tool rest. No other accessories included as I told him I didn’t need them. Any advice on how much it’s worth?
-- Mark, North Carolina
31 replies so far
5143 posts in 2668 days
#1 posted 04-21-2015 11:01 AM
I have one, though mine is highly modified making my price comparison invalid (I think). I would guess somewhere in the $600-$700 range would be about right. This lathe is very close (and the predecessor to) the 1624. Look at the new prices of it and the outboard tool rest to see about what the new value would be and go from there. I think the outboard tool rest (I do have that) is north of $200 by itself. One thing to consider: I don’t think bed extensions are available for that model any more, so if it doesn’t have one (making the distance between centers about 40” or so) you may be stuck with what the length is, or find a used one. They are very good lathes.
View LeeMills's profile
LeeMills
610 posts in 1476 days
#2 posted 04-21-2015 01:23 PM
As Fred stated, the 3000 was the predecessor to the 1624 and the DVR XP. The 3000 came either with belt, like the 1624, or with DVR. With belt drive I agree with the $650 range, about 1/2 the new price. If it is the 3000 DRV then it is probably worth more as a new DVR is in the$ 2000 range.
I have the 1624 and have never needed more the 24” between centers but I don’t do table legs either.
You should be able to just look at the headstock and tell if it is belt or DVR.
If he has other accessories such as chucks you may take a look at them also. You can never have too many chucks. :)
GCIMark
#3 posted 04-21-2015 01:48 PM
Thanks to both of you for the input!!!
Lee, I don’t know enough about this lathe to be able to tell the difference between the belt drive or the DVR that you mentioned. I attached a photo of the lathe in hopes that you might tell me which it is. Also, looks like it may already have a bed extension, yes?
#4 posted 04-21-2015 04:22 PM
Not lee, but yes to both. That is the belt drive, and it has the extension. Would make you a great lathe if the price is right.
View Woodknack's profile
Woodknack
12399 posts in 2555 days
#5 posted 04-21-2015 04:27 PM
See the box sitting on the DC motor… unless I am very mistaken, that is a variable speed unit. Price depends on where you live. I think if you can get it for $1000 anywhere you are doing good.
GCIMark
#6 posted 04-21-2015 05:02 PM
That box has Leeson Speedmaster written on the top of it (there’s another picture of it). There are 3 toggle switches and a big round knob in the center with numbers around the knob. That’s exactly what the guy said he would take – $1000.
#7 posted 04-21-2015 05:49 PM
Is that $1000 for the lathe and the speed control?
GCIMark
#8 posted 04-21-2015 06:10 PM
Yes. Everything in the pictures above except for the stuff on the bottom shelf of the stand.
#9 posted 04-21-2015 06:28 PM
Well, back to what I said about my lathe: it’s highly modified, maybe to accomplish the same thing that speed control does. Mine had the original motor removed and a bracket fabricated to hold a Baldor 1.5 HP 3 phase motor. That, in turn, was hooked to an industrial GE VFD…so I have full motor speed range no matter where the belts are located (there are limitations to that in terms of turning). It had the same frame/extension/outboard tool rest you show. I paid $1000, last year. It sounds to me like you would have about the same setup, and he wants the same price. I still think that’s a little high, but I was willing to pay since around me such tools don’t show up for sale very often; even at that, I had to drive about 100 miles to get mine. Mine did have the tailstock upgraded to the DVR version, but that’s of limited value, I think. The limitations I mentioned, when I control the motor speed the torque drops with the frequency…so you can’ just use one lathe belt setting and vary the motor. With each belt setting you can vary the speed enough to do some nice things, but there will be a point that you have to move the belt up (or down) to have enough torque. The nicer lathes that have EVS have that as well, but they usually only have 3 (or fewer) belt settings, and often larger motors. The 3000 has 8 belt speeds, BTW.
LeeMills
#10 posted 04-21-2015 06:49 PM
There is a good chance those came with a Leeson controller. Here is a listing on the bay (your’s looks much nicer condition to me). The controller is mounted on the end.
http://www.ebay.com/itm/TEKNATOOL-NOVA-3000-WOOD-LATHE-ON-STAND-/391103758991?pt=LH_DefaultDomain_0&hash=item5b0f99c28f
GCIMark
#11 posted 04-21-2015 06:51 PM
I know what you mean about them not showing up for sale. I’ve been looking to upgrade for quite some time. I look at CL almost on a daily basis. I look at a ten state area, more or less and I’ve only seen three or four 3000’s and this one is in the best shape and had the most extras. The bad thing is this guy is 300 miles from me. I found a gently used 1624-44 originally listed for $700. After a month or so it showed up with a new $500 price tag. I contacted the guy and made a deal and made plans to go pick it up last Sunday. On Saturday night, in the true spirit of many Craigslisters, the guy calls me up and tells me he sold it. So, I’m still looking. Any opinion on Shop Fox?
#12 posted 04-21-2015 07:52 PM
Wow, that one on e bay doesn’t have the outboard rest or the bed extension…those 2 together are probably $300+ add ons, and he wants $1500?
GCIMark
#13 posted 04-21-2015 07:58 PM
Does that mean the one on eBay is overpriced or the one I’ve found is a really good deal. Or a little of both? Shop Fox??
Woodknack
#14 posted 04-21-2015 08:03 PM
Used lathes are getting expensive. Around here a 4 speed 12” lathe will advertise at $500-$600. Even tube lathes are edging over $100.
View Arlin Eastman's profile
Arlin Eastman
4249 posts in 2736 days
#15 posted 04-21-2015 08:32 PM
Mark
I seen the 3000 go from $300 to $900 depending on the care of the lathe. Although it looks nice it also looks like it has been used a lot more then the seller is saying.
The new 1642 is belt driven and costs $700 new when it goes on discount once a year along with the all the Nova lathes including the DVR 16” and 20”.
Personally I really think the price should be no more then $650. It looks like it is missing the face plate and spur drive which will cost you $45 for both of them at Penn State Ind.
One of the problems with this model is the bearings got hot if someone put to big a piece on it and tightened the tail stock down to tight. So I would listen to it run with nothing attached and hear what it sounds like. Then put on a block of wood 4×4x2 and run it for 10 minutes and feel the front side of the casing for heat. If you do feel anything over very mild warm you will have to change the bearings and should only pay him $250 to $300 at most.
-- It is always the right time, to do the right thing.
showing 1 through 15 of 31 replies
