What size lumber is this bench made from?
Forum topic by Dan Hux posted 07-27-2009 08:46 PM 1330 views 0 times favorited 7 replies Add to Favorites Watch
View Dan Hux's profile
Dan Hux
577 posts in 3576 days
07-27-2009 08:46 PM
Topic tags/keywords: question
Hi,
can someone tell me what size lumber this bench is made from. I’d like to make a bench like it, but don’t have enough experience to tell what this is made from ie: 1×4, 1×6, 2×4,2×6. I think it would look great with walnut legs and support beams, with maple arms, seat slats and back slats.
thanks in advance.
dan
this link has the bench..
http://www.grandinroad.com/jump.jsp?item=24220&maincatcode=null&subcatcode=null&itemID=19664&itemType=PRODUCT&path=1%2C2%2C434%2C4755&iProductID=19664
-- Dan Hux,,,,Raleigh, NC http://whitdaniel.com
7 replies so far
View PurpLev's profile
PurpLev
8547 posts in 3850 days
#1 posted 07-27-2009 08:48 PM
which bench are you referring to? if you tried to put a picture into the post – it didn’t work. is there a link to the bench you are questioning about? or a picture of it?
View waroland's profile
waroland
48 posts in 4088 days
#2 posted 07-27-2009 09:10 PM
Looks like 0/4 to me.
-- waroland, Mount Juliet, TN
Dan Hux
#3 posted 07-27-2009 11:34 PM
PurpLev
#4 posted 07-27-2009 11:38 PM
looks like 5/4 mostly (~1 1/8”” thick in it’s final size)
Edit… or maybe 6/4
my suggestion for you is, roughly design the piece, and then on paper, try it both with 6/4 and 5/4 and see which one looks better… but this is the approximate size of the lumber roughly.
View hObOmOnk's profile
hObOmOnk
1381 posts in 4329 days
#5 posted 07-27-2009 11:52 PM
The overall measurements are given in the description.
Estimate the seat height to be 18”.
The board widths appear to be a generous 1” thick.
I zoomed in and used a caliper to take measurements, then calculated the ratios.
Allow for perspective.
-- 温故知新
Dan Hux
#6 posted 07-28-2009 12:29 AM
thanks folks,,good info..
35148 posts in 4602 days
#7 posted 07-28-2009 01:30 AM
I would think 5/4 for the thickness of the leg. Probably 4” wide at the bottom
-- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Appomattox Virginia karsonwm@gmail.com †
