removing glue from sanding belts?? any suggestions.
Forum topic by Bob #2 posted 07-27-2009 06:23 PM 1304 views 0 times favorited 7 replies Add to Favorites Watch
3809 posts in 4018 days
07-27-2009 06:23 PM
Topic tags/keywords: glue remover sanding belt juvenation belt cleaner question
I have parked a couple of belts ( wraps) that I loaded with glue sanding down a few glue ups.
Right now I have one sitting in water and Cascade dishwasher detergent,
The glue has softened but is still to thick too brush off.
I heard Simple Green works but havent tried that.
Anyone have a sure fire cleaner they could recommend?
7 replies so far
View Dan'um Style's profile
Dan'um Style
14172 posts in 3979 days
#1 posted 07-27-2009 06:56 PM
Hello Bob
You might try a heat gun to soften the glue and then brush it off.
Regards
DAN
#2 posted 07-27-2009 07:07 PM
Hi DAN, that’s where I started with this one. I was removing heavy glue fromthe bak of a board I want to restore so it could be glued again. The glue lifted in some spots but was too well bonded in others rendering the surface useless. If I scrubbed too hard witha wire bursh I hae not abrasive left.
Seems to me that somebody mentioned vinegar to me but I’m not sure it will dissovle aliphatic glue.
View Greg Wurst's profile
Greg Wurst
794 posts in 3828 days
#3 posted 07-27-2009 07:21 PM
Have you tried one of those large eraser sticks? They’re great for removing sanding residue but I don’t know about glue.
View GMman's profile
GMman
3902 posts in 3693 days
#4 posted 07-27-2009 07:51 PM
contact cement remover will do it.Use a small brush
View DrDirt's profile
DrDirt
4424 posts in 3738 days
#5 posted 07-27-2009 08:31 PM
There was a post on here I didn’t try but they mentioned that a piece of white PVC pipe worked better at removing crud off of belts better than the big gum rubber erasers..Maybe it is just hard/sharp enough to get the crud out.
Dan'um Style
#6 posted 07-29-2009 05:39 AM
another house hold item that will probably work is shaving cream … a few years ago I bought a old police car and the adhesive would not come off with any other way. even automotive adhesive remover wouldn’t work, so I did a Google and someone suggested shaving cream. I went to the dollar store and bought a can. it is the lanolin that dissolves it I think.
#7 posted 07-29-2009 01:27 PM
That’s certainly worth a try Dan.
I’ve run out of cleaning things around the house.
I’ll keep you posted
