Recommendations for finish on outdoors oak furniture?
Forum topic by Goss posted 04-18-2015 08:27 PM 1123 views 0 times favorited 14 replies Add to Favorites Watch
View Goss's profile
Goss
9 posts in 2146 days
04-18-2015 08:27 PM
Let me pick your brains….
If I were to make a simple bench out of American white oak that is situated outdoors, does anyone know what the best kind of clear finish to put on it would be?
It does rain a lot here (UK)
Cheers
-- cut twice, measure once, or is that the other way round?
14 replies so far
View Yonak's profile
Yonak
986 posts in 1426 days
#1 posted 04-18-2015 08:52 PM
Great question, Goss. All wood that is outdoors will require some on-going maintenance. How often it will need attention depends on several factors :
First, how much exposure it gets. If it is taken indoors except when used or before any inclement weather or baking sun, much less maintenance will be required than if it is kept out all the time in all kinds of weather. Always being kept under good shelter or kept covered with a tarp are also helpful measures to lessen the maintenance required.
Second, what type of finish is put on. It’s my opinion that good outdoor paint will last the longest but, often, that’s less preferred because it hides the beautiful wood underneath. Some like marine varnish. It lasts a good while but it’s pretty expensive.
I, myself, tend toward oil finishes because they can be wiped on, making periodic maintenance less burdensome than brushing or spraying it on and they are fairly inexpensive. The maintenance is pretty regular but it’s pretty easy.
The least preferred finish, I have heard, would be commercially prepared waterproofing as they tend to last the shortest time, thereby requiring the most regular attention.
I would love to hear others’ preferences on this.
View Logan Windram's profile
Logan Windram
344 posts in 2367 days
#2 posted 04-18-2015 09:47 PM
You could do no finish, let it gray.
But I’d venture to guess spar varnish, I think it is formulated for marine use with added UV protection
View gfadvm's profile
gfadvm
14940 posts in 2595 days
#3 posted 04-19-2015 12:18 AM
I have used Spar Urethane and DO NOT recommend it! A few months of our sun and it cracked and peeled. BLO makes the most sense to me as it is so easy to redo as needed. Maybe wax over the BLO.
View pjones46's profile
pjones46
1000 posts in 2548 days
#4 posted 04-19-2015 03:42 AM
+1 Yonak
-- Respectfully, Paul
View Rick's profile
Rick
8899 posts in 2937 days
#5 posted 04-19-2015 06:26 AM
I tend to agree with Yonak.
”I, myself, tend toward oil finishes because they can be wiped on, making periodic maintenance less burdensome than brushing or spraying it on and they are fairly inexpensive. The maintenance is pretty regular but it’s pretty easy.”
The oil tends to just keep soaking in and even if it fades due to the Sun or other conditions, usually a light wipe over, or a light brushing with the same product brings it right back.
Rick
-- I Take My Kids Everywhere! The Problem Is, They Keep Finding Their Way Back Home! (Rick, Ontario, Canada)
runswithscissors
2654 posts in 1930 days
#6 posted 04-19-2015 06:47 AM
I’ve seen unprotected oak turn kind of splotchy or streaky black from weather, rather than gray as teak tends to do. It’s pretty ugly (sort of an oxymoron there, eh?)
View bbasiaga's profile
bbasiaga
1119 posts in 1900 days
#7 posted 04-19-2015 07:57 AM
Here in the US we have something called Thomson’s water seal. It is used for decks outdoors. It is available clear or tinted and causes water to bead up on the surface of the wood. Needs to be reapplied each year usually. Something like that might work if it is available over there. I wonder if it could even go over the top of an oil finish like a Danish Oil or something?
-Brian
4874 posts in 2398 days
#8 posted 04-19-2015 11:26 AM
With no knowledge of what finishing products are available to you, you should give untinted exterior paint some consideration. The paint base will have UV inhibitors, and be very durable. Be aware, any clear finish will need repair after a while, but this will last a very long time. The only thing I like better is a true marine spar varnish, like Epifanes. I have used some waterborne exterior paint, but the item hasn’t been out in the waether enough yet to pass judgement (one year). But a product like Olympic Icon exterior #5 base dries clear.
View redSLED's profile
redSLED
790 posts in 1797 days
#9 posted 04-19-2015 05:26 PM
Light sanding and oil finish/BLO every spring. Only uncover during good weather. For various reasons most people can’t execute this simple routine. I also do not recommend spar varnish UV protected or not – it doesn’t last and yearly maintenance is a hassle compared to oiling your bench.
View Goss's profile
Goss
#10 posted 04-19-2015 05:56 PM
Thanks everyone for your input. I am leaning towards an oil finish for ease of maintenance, the design is such that a wipe on finish will be much easier to apply than something that has to be brushed.
Oil it is.
Cheers.
View RobS888's profile
RobS888
2386 posts in 1750 days
#11 posted 04-19-2015 07:58 PM
Goss,
Don’t forget to seal the ends that sit on the ground with glue. Let the end grain soak up the glue, then it won’t soak up water later.
-- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list.
pjones46
#12 posted 04-19-2015 09:36 PM
Make sure the stain is for exterior use like tranparent decking stain so it will not rub off on clothes.
View Rick's profile
Rick
#13 posted 04-20-2015 06:47 AM
Oil it is.
Cheers.
- Goss
Good Choice!
View dhazelton's profile
dhazelton
2687 posts in 2201 days
#14 posted 04-20-2015 02:10 PM
I was painting a house and they had several surfaces that they varnished when they were installed. A door and some window surrounds faced southwest and sun and rain. A porch deck faced north and had shade all day long. The porch deck held up well and just needed a light sanding and topcoat to put some gloss back. I had to scrape and sand all the other areas that faced the weather. I used marine varnish the first time (I don’t know what the original finish was) and next year they wanted it done again as it already was failing. I went the untinted oil based paint route and it looked great. For a year. They finally caved in and asked me to use paint on the surfaces that see heavy weather. They bought Behr latex enamel and it has held up much better. Varnish and oil based paints just don’t flex at all.
