Morning all. In an up coming Hutch & buffet project I will be making 3 sold hardwood drawers. I will try my hand at hand cut dove tails. The question is. The fronts will be 3/4" thick, is 3/8" to thin for the sides?
Thanks
I'm no expert, but I think through dovetails pretty much require same thickness for the tail boards and pin boards (sides and front/back).
I think for non-through you can get away with different thicknesses, but I think it is less common to make those by hand. (lots of end-grain chiseling).
I usually go with 1/2" sides and half blind dovetails. 3/8 would work just need a little shallower dado for the bottom. 3/8 would work fine for the dovetails thru or halfblind.
It depends on the size of the drawer For a small jewelry box 1/4" might be too thick and on big drawer in a workbench 3/4" might be needed to hold heavy tools. I like to keep things proportional in relation to the size of the drawer and weight of the expected contents. For large drawers on dressers I think 1/2" is about right. It's really up you and your sense esthetics and the functionality you want to build into the piece.
I should have stated earlier, I'll be using half blind dovetails in the front…not sure about the back. Thanks for the input so far
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
