pouring a drive way 10' wide with a 90 degree curve
« back to Coffee Lounge forum
Forum topic by rf58 posted 04-18-2015 05:26 AM 1204 views 0 times favorited 7 replies Add to Favorites Watch
View rf58's profile
rf58
78 posts in 3081 days
04-18-2015 05:26 AM
Topic tags/keywords: question
where do i cut score marks in it all my friends are woodworkers and even concrete guys have different ideas is there a rule for this.
-- rf58, Illinois
7 replies so far
View johnstoneb's profile
johnstoneb
2691 posts in 2044 days
#1 posted 04-18-2015 11:07 AM
8’ to 10’
-- Bruce, Boise, ID
View Crank50's profile
Crank50
173 posts in 1447 days
#2 posted 04-18-2015 01:25 PM
What ever spacing you decide on, 10 ft for instance, is to be measured at the outside radius.
I would measure the radius from the center point, multiply by pi, then divide by 2. That is the distance around the 90 degree arc. Then divide that distance by 3 or 4 or 5 to try to get close the the 8 to 10 ft distance.
Example for a 30 ft outside radius.
(30 X 3.1415) / 2 = 47.122 ft.
You can see that if you rounded that up to 50 ft it would be 5 sections at 10 ft
So divide 47.122 by 5 and get 9.42 ft.
That would be 9 ft – 5 inches.
Don’t forget, if you want 5 sections, you need 6 cuts.
View rf58's profile
rf58
#3 posted 04-19-2015 04:22 AM
the pie shaped pieces should be like this so if the circumference is 56 ft =672” divided by 6 sections each section at the outside should measure 112 inches.
and the inside is 36’ =432 ” divided by 6 sections 72”
i will draw that out on the ground ad see what it looks like.
-- rf58, Illinois
View BurlyBob's profile
BurlyBob
5145 posts in 2137 days
#4 posted 04-19-2015 04:30 AM
I’m no expert but I’ve done a little concrete. It sure looks to me like a score in the center of that arc would be a good idea.
View rf58's profile
rf58
#5 posted 04-22-2015 02:32 AM
-- rf58, Illinois
Crank50
#6 posted 04-22-2015 06:26 PM
Looks like too many cuts, but I suppose that’s because your arcs are not drawn to scale.
Also, you have 6 sections (7 cuts) instead of 5, but I guess you rounded 56 up to 60.
If the layout looks too tight in full scale , round down the number of sections.
View rf58's profile
rf58
#7 posted 04-27-2015 05:01 AM
WHAT I THINK WE ARE GOING TO DO IS JUST 3 MAJOR SECTIONS WITH THE CALIFORNIA STYLE.USING THE CENTER EDGER AND SAW CUT THE IN BETWEEN SECTIONS.
-- rf58, Illinois
