Question for the Home Repair types
« back to Coffee Lounge forum
Forum topic by interpim posted 07-24-2009 07:10 PM 1245 views 0 times favorited 18 replies Add to Favorites Watch
View interpim's profile
interpim
1170 posts in 3364 days
07-24-2009 07:10 PM
I have a central cooling unit drain from my 3rd floor that drains over my back door… it is also getting the side of my house really wet. What would you guys recommend I do to at least get this water from dripping just outside my back door?
Here is what I am looking at.
-- San Diego, CA
18 replies so far
View Christopher's profile
Christopher
576 posts in 3826 days
#1 posted 07-24-2009 07:13 PM
Does it drain onto the roof then over the edge? Your link doens’t seem to be working, don’t know what I am looking at.
Christopher
#2 posted 07-24-2009 07:14 PM
Christopher
#3 posted 07-24-2009 07:16 PM
woops, sorry about the previous ’!’ post. I tried to edit something but it went all awry on me.
interpim
#4 posted 07-24-2009 07:19 PM
I had to fix it… the auto image loader thing messed up the link.
in the image, the drain is at the top and drains just to the right of the small roofed area… which is where my back door is.
-- San Diego, CA
View Abbott's profile
Abbott
2570 posts in 3209 days
#5 posted 07-24-2009 07:20 PM
From the photo I can only see that you have an issue that needs to be resolved. I can not see where or what the drain is. My first thought would be to install a longer drain line (3/4” PVC, which is pretty standard for HVAC units) that reaches to just a few inches above the ground.
-- Ohh mann...pancakes and boobies...I'll bet that's what Heaven is like! ♣ ♣ ♣ ♣
interpim
#6 posted 07-24-2009 07:22 PM
Hopefully this will be a better image
-- San Diego, CA
View sIKE's profile
sIKE
1271 posts in 3660 days
#7 posted 07-24-2009 07:29 PM
Yep get some Schedle 80 PVC (the grey type) as it is UV resistant, and route it around the window to the ground. You can paint it the same color as the Stucco once you get it all together.
View John Ormsby's profile
John Ormsby
1283 posts in 3643 days
#8 posted 07-24-2009 08:42 PM
It is code to put the drain line above a window. I normally run the drain down a wall and exit close to the ground. I don’t know what the code is in your area, but I would ask myself, what is worse? a rotten wall and window to contend with or a pipe that is going down the wall. If you do bring a pipe down the outside wall make sure you paint it. It will protect the pvc from dying and cracking prematurely.
-- Oldworld, Fair Oaks, Ca
View depictureboy's profile
depictureboy
420 posts in 3548 days
#9 posted 07-24-2009 09:03 PM
ok…thats a case of stupid code…code should make it come out at ground level….
-- If you can't build it, code it. If you can't code it, build it. But always ALWAYS take a picture.
View lew's profile
lew
11942 posts in 3661 days
#10 posted 07-24-2009 09:05 PM
Around here there many dairy farms. These operations use clear, flexible PVC tubing of various diameters. Running a line from the drain to a more convenient location would not be as noticeable and easily formed with this type of tubing.
View childress's profile
childress
841 posts in 3448 days
#11 posted 07-24-2009 09:54 PM
the drain is put above a window so that you know when it is draining. This drain is not supposed to serve as a main drain, it’s there to let you know that the main drain is clogged. Typically, they will drain the unit into the master (or whatever is closer) bathroom sink drain. Check in your bath cabs and see if you see the drain, maybe it’s clogged right there.
-- Childress Woodworks
View SCOTSMAN's profile
SCOTSMAN
5845 posts in 3491 days
#12 posted 07-24-2009 10:07 PM
Can’t you even tie it to a downpipe or gutter pipe going down then it wouldn’t look so bad.This is a mess I wouldn’t like this either. Alistair
View reggiek's profile
reggiek
2240 posts in 3176 days
#13 posted 07-24-2009 10:27 PM
Those drains are set up to take the condensation out of the system so that the unit is not damaged by rust and moisture. You might check to see if the unit has another drain….but if it is just an air conditioning system (self contained – using a refrigerant it probably does not – if the unit is a swamp type – or evaporative cooler – then it would definitely have a bigger main drain).
I would then do as sIKE remarked and reroute that drain. I wouldn’t use any hose or other flexible media as it will have a tendency to slap at the wall during windy or stormy days…and this would be more annoying.
interpim
#14 posted 07-24-2009 11:48 PM
This is a heat pump type air conditioning… it is Military housing, so I am not sure how much I can modify anything.
This is similar to what I have sitting outside
-- San Diego, CA
View northwoodsman's profile
northwoodsman
242 posts in 3652 days
#15 posted 07-25-2009 02:16 AM
Childress is correct. If you have water coming out of this you have a problem. Once a month I pour 2 cups of a mixture of 50/50 bleach/water down my main lines ( have 2 units). Several HVAC guys have told me to do this.
-- NorthWoodsMan
