Infinity explains the up/down spiral router bits
Forum topic by waho6o9 posted 04-17-2015 03:42 PM 1731 views 0 times favorited 12 replies Add to Favorites Watch
View waho6o9's profile
waho6o9
8473 posts in 2746 days
04-17-2015 03:42 PM
Topic tags/keywords: solid carbide spiral router bits
http://www.infinitytools.com/Solid-Carbide-Spiral-Router-Bits/products/1088/?utm_source=Flash+-+Solid+Carbide&utm_campaign=10%25+Off+spiral+bits&utm_medium=email
Excellent video from Infinity tools on the differences between up cut and down cut
spiral bits. Compression bits explained as well.
These new fangled bits are great.
Good stuff.
12 replies so far
View ward63's profile
ward63
353 posts in 3256 days
#1 posted 04-17-2015 04:14 PM
Whoa! The new fangled bits are some new cutters to try.
Do have a link for new fangled bits?
Thanks for sharing
waho6o9
#2 posted 04-17-2015 04:43 PM
ward63
#3 posted 04-17-2015 04:57 PM
Thank you, but I’m still looking for the new fangled bits on the site, can’t find them anywhere.
View longgone's profile
longgone
5688 posts in 3478 days
#4 posted 04-17-2015 05:00 PM
Good stuff.
- waho6o9
The bits in the photos are Whiteside router bits. I don’t believe Infinity makes any like these. I’ve been using the double bearing Whiteside compression bit for quite a while and it is a great bit. When I was looking for a larger compression bit with upper and lower bearings only Whiteside had them…maybe that has changed?
ward63
#5 posted 04-17-2015 05:07 PM
Thanks, I checked the Infinity site a couldn’t find them anywhere. If Whiteside has these then their gonna be major $$$$. Looked interesting though.
Thank you
waho6o9
#6 posted 04-17-2015 05:11 PM
http://www.carbideprocessors.com/whiteside/whiteside-ultimate-trim-bit-series/
You’re correct Folks, I apologize it’s from Carbide Processors
waho6o9
#7 posted 04-17-2015 05:12 PM
Our Low Price:
$133.92 (You save $53.57)
SKU:
412-UDC9112
Brand:
Whiteside
Reviews:
Write a review
Ask a question
Availability:
Due to immense popularity, there is about a 1-2 week lead time on Whiteside Ultimate Trim bits
ward63
#8 posted 04-17-2015 05:28 PM
Nice bits!!! Too big for my uses. I generally stick to 1/4 or 3/8 inch with 1/2 inch being a rarity.
Thank you for showing what’s new :-)
waho6o9
#9 posted 04-17-2015 05:36 PM
You’re welcome Ward63.
It’s amazing how these new bits work with zero tear out when
used properly.
I used the pattern bit and the cut was smooth as glass with no tear out
on the top and bottom of the plywood.
View Moron's profile
Moron
5032 posts in 4063 days
#10 posted 04-17-2015 09:49 PM
its not new
its just new to those who aren’t in the trade
keeping up on the newest and greatest innovations, be it hardware, be it tooling, be it tools
is almost always decided by the result of having perfection
be it a hand plane
a bench
or unparalleled engineering
none of which come cheap : )
View kdc68's profile
kdc68
2689 posts in 2446 days
#11 posted 04-17-2015 11:56 PM
Thanks for the post. I’ve seen them before via Eagle America I think and wondered if the $$ was justified. Glad you had the results you did using them. When the wallet gets fattened up some, I will consider buying them…..
-- Measure "at least" twice and cut once
24504 posts in 4020 days
#12 posted 04-18-2015 01:13 AM
Thanks for the info Waho609
