| Forum topic by Hawgnutz | posted 445 days ago | 296 views | 0 times favorited | 9 replies | ![]() |
445 days ago |
Topic tags/keywords: end grain accents I have a bandsaw box that has some interesting small checks in the end grain. I could sand or cut them out, but I would like to highlight them as part of the design. Can I dye some wood filler to accent them? They look like some rays of the sun. God Bless, -- Saving barnwood from the scrapyards |
445 days ago |
If the checks are stable, should work fine. You will stain the surrounding area, so apply with care. Be sure to use a stain that is compatible with your filler (water based stain for water based filler etc…) -- Nicky |
445 days ago |
I guess I did not make my question clear. I would like to stain the filler, then “pack” it into the cracks, and finish the wood, as usual. I want the checks to be accented, not covered up. The cracks look to be atable. Could I stain some epoxy with some red oak stain by minwax and pack that in the checks? The wood is redwood, and I will use some purpleheart inlay. God Bless, -- Saving barnwood from the scrapyards |
445 days ago |
You can use TransTints for most any tinting process. Rockler, Woodcraft, Highland Woodworking -- No piece is cut too short. It was meant for a smaller project. |
444 days ago |
You were clear, in looking at my response; I don’t think I was clear. I’ve done this, on a band saw box. You can stain filler. You should mix in a stain/tint that is compatible. If you’re using water based filler, then use water based stain. You can also buy fillers that are colored/tinted. When you apply the filler to fill the checks, the surrounding area will absorb some of the moisture from the filler, so use sparingly, else the area you are trying to fill will blend, and you won’t have the contrast you’re looking for. -- Nicky |
444 days ago |
Thanks, Nicky. I am planing to stain the wood the same color, just a lighter sade. This is on a piece of “scarp” redwood cut off from a fence post. I was going to just toss it in the trash, but it kept crying out to me, “Look! I am a box waiting to be made!” So, I am making a box, maybe as a Christmas gift for my neice. Here’s my plan: I am going to blend some minwax red oak stain into my wood filler taht is touted as “stainable” using a putty knife. I will “pack” it in the checks, and then sand and scrape the extra off and then apply a gel finish to teh rest of the wood. I am hoping that the putty will be a darker shade and will radiate on the ends. The tropical storm, Henriete is due to blow in early morning, so I will be doing it inside my shop tomorrow, and cut it out with bandsaw. I will post it soon. Thanks for the advice. God Bless, -- Saving barnwood from the scrapyards |
443 days ago |
Stay safe! -- Nicky |
443 days ago |
Hello Hawg; If I am reading you right in your question here you are also wondering about keeping the color in the filler from spreading to the surrounding wood. I usually will in cases such as this tape off the surrounding wood, with masking tape and then proceed with a filler. After the filler has staterted getting a good set, I will then scrape off the excess with a putty knife….let dry and if another application is needed I will then reapply. Granted yes, the time spent for masking will take some time, but I have also found that this is time well spent since the surrounding wood stays free from color contamination. You may also note from the following photos that I cannot always get all checks and cracks in one taping, so then I will go back and tape and fill those other areas that need to be protected.
....and….
....and….
....and….
....and….
Now bear in mind that there is no one way to do this and what I have learned to do is//has only been proven to work for my satisfaction. But then I also am always amazed and pleased at the final outcome….
This is not wood putty, since wood putty will over time start to chip and wear out due to wood movement. I use a two part polymer system, to which I add crushed up artist chalk to achieve the colors I am going after….
....and….
....and….
I hope this helps some more along with all the other fine solutions you have been offered here. And rest assured that the taping process for what you are doing will not get as involved as what I am showing you here in my project….I had about three days of taping miny minute silvers of masking tape to get the curves all worked out and protected….but in the end I was satisfied.
Thank you. -- --frank, NH, http://frank.wordpress.com/ |
442 days ago |
Frank, That is a beautiful slab! Much, much larger than the little box i am making! Interesting, though. Where do you get the polymer? God Bless, -- Saving barnwood from the scrapyards |
442 days ago |
Turners face this stuff all the time. Craft Supply and a few others supply all sorts of stuff. Ground turquoise, coral, malachite, and other minerals, brass, silvertone and goldtone stuff. Coffee grounds work well if you want to go dark. With these things, you do your coloring before it hits the gaps, though. Nice touches. Saw one last night that used Corian dust! -- Dean, Missouri |
| Sponsor | Forum | Topics |
| Become a sponsor |
Woodworking Skill Share
1336 |
| Become a sponsor |
1778 |
| Become a sponsor |
123 |
| Become a sponsor |
371 |
| Become a sponsor |
108 |
| Become a sponsor |
Woodworking Trade & Swap
251 |
| Become a sponsor |
Coffee Lounge
1003 |
| Become a sponsor |
LumberJocks.com Site Feedback
284 |
