Forum topic by kevinmcgee | posted 04-16-2015 08:39 PM | 680 views | 0 times favorited | 3 replies | ![]() |
I used T-9 cleaner on my table saw and it left small “spots”. The pump spray wouldn’t work, so removed the cap and sprinkled the cleaner on the table and that’s when the spots formed. I tried removing them with WD-40 with no luck. Any suggestions on how to remove the spots? Thanks, Kevin |
3 replies so far
#1 posted 04-16-2015 09:09 PM |
T-9 is basically just mineral oil and paraffin wax dissolved in mineral spirits. Try wiping it down with mineral spirits. A scotch brite pad helps if it’s stubborn. Cheers, PS: For real stains, a dilute solution of phosphoric acid, alcohol and distilled water works great. -- Brad in FL - In Dog I trust... everything else is questionable |
#2 posted 04-16-2015 09:30 PM |
you could try autosol. works very well |
#3 posted 04-17-2015 02:14 AM |
Did you use Boeshield T-9 or Boeshield Rust-Free?? T-9 spray is generally aerosol and is a protectant, Rust-Free is a cleaner and the bottles are pump sprays. I can’t imagine T-9 causing any damage to metals, but even Boeshield warns that Rust-Free can cause spotting in cast iron. From the Boeshield web site regarding Rust-Free: Test on hidden area before use. earl |
Forum | Topics |
Woodworking Skill Share
12031 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4905 |
6695 |
28061 |
CNC Woodworking
212 |
Hand Tools
5411 |
Jigs & Fixtures
1419 |
Wood & Lumber
6233 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4757 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
