Depth of Harbor Freight 60 inch bench
Forum topic by natenaaron posted 04-16-2015 08:30 PM 1317 views 0 times favorited 17 replies Add to Favorites Watch
View natenaaron's profile
natenaaron
442 posts in 1703 days
04-16-2015 08:30 PM
I am completely fed up with my current wobbly too short work table. Plus it is too damn big. I have been reading good reviews of the 60 inch bench from HF and before I go get one this weekend I was wondering about the depth. 20 inches sure does not seem like a lot.
Those of you who have these, do you find yourself wanting a deeper bench?
Forgot to mention my current table is 6’x8’ That big a table is not luxury it is a PIA.
Thanks.
17 replies so far
View Ocelot's profile
Ocelot
1883 posts in 2543 days
#1 posted 04-16-2015 08:37 PM
I have 2 of those benches. 20” is fine for a work surface. The HF bench is an OK place to put your benchtop drillpress or dovetail machine. However, the HF bench is not really sturdy enough for handplaning, I have found.
You get a usable little vise and 4 drawers in it too, which is nice, considering the cost.
I’m fixing to build shipwright’s V8 bench.
-Paul
View TheFridge's profile
TheFridge
8886 posts in 1391 days
#2 posted 04-16-2015 08:40 PM
I just built a bench with 20” depth. Depends on you really. The things I work on are usually 24×24 or less
View jakep_82's profile
jakep_82
105 posts in 2211 days
#3 posted 04-16-2015 08:55 PM
If you’re concerned about wobble, don’t get the HF bench. I’ve done some planing on mine, and it’s not a great experience. I use mine for benchtop tools and some assembly work, but I would steer clear for much else.
View unbob's profile
unbob
801 posts in 1809 days
#4 posted 04-16-2015 08:59 PM
Glue the thing together add some bracing, then its reasonable for hand planning.
View MrRon's profile
MrRon
4632 posts in 3149 days
#5 posted 04-17-2015 07:42 PM
Like anything else HF sells, much improvement can be attained with a little tweaking or adding some bracing in the case of their workbench. Putting better wheels on a bench grinder for example gets you a tool that is equal to one costing 3x more.
Ocelot
#6 posted 04-17-2015 07:46 PM
Just to be clear, I think the HF bench is a great value and quite usable for some things. And, I’m sure, as has been pointed out that with bracing, it can easily be made even better. It’s a great, quick, starting point.
View OSU55's profile
OSU55
1522 posts in 1895 days
#7 posted 04-18-2015 01:58 AM
I have one that I do a lot of handplaning on. Each end has 1/2” plywood boxing the legs in (outside only) and serving as hand plane racks, and the back has a large piece of pegboard stretched between legs. No excessive wobble from it. I find the 20” to be about right for most things. I have other tables/benches used for some assembly, etc. I wouldn’t want one over 24”.
View benchbuilder's profile
benchbuilder
284 posts in 2356 days
#8 posted 04-18-2015 02:09 AM
I believe you can go to the local HD or lowes and buy enough 2 by lumber to build a bench much stronger then the HF junk. They are too light too narrow and poorly built. I have seen that bench and in six months you will be wishing you never seen it. This is only my thoughts on it.
unbob
#9 posted 04-18-2015 05:45 AM
This is a HF bench that I re-worked and braced up a little. With a coupon and maybe a sale around $100. One cant buy the material for that… I added a leg vise and re-did the end vise.
unbob
#10 posted 04-18-2015 05:50 AM
a 2×6 brace running under the bottom shelf and a view of the leg vise brackets I made. I have gathered enough maple to build a better bench, this HF one will be nice to help fabricate the new one. The last thing I would do is build a bench out of 2×4s. That is a fairly large piece of Snake wood I am planning on that bench. Also note the brace running along the back side flush with the top about mid way on the legs. Toss a hundred pounds of hand planes on the bottom shelf, and it can be pretty solid work bench.
View MrUnix's profile
MrUnix
6351 posts in 2104 days
#11 posted 04-18-2015 05:53 AM
If you live anywhere near where there are some constructions sites, you generally don’t need to buy any material :)
Every weekend I take a drive through the various new residential areas around my house that have a few new homes being built. You can find all sorts of 2x and 4x material (and even larger) in various lengths, plywood, wiring, laminated goods, ducting, tubing, pvc and metal pipe, sheet metal and all sorts of other stuff just sitting there in the dumpster for anyone willing to snag it. It is really amazing at what you can find if you look. Some weekends there won’t be squat… other weekends I’ll hit a gold mine. After a while, you will have so much lumber that you won’t know what to do with it all!
PS: Pallet wood is also a great source of hardwood, and while you may not want to make furniture for the house out of it, it’s great for making stuff for the shop.
PSS: Another alternative is to find vintage metal desks on CL for cheap… built like a tank and make great work benches and tool stands with plenty of storage in the drawers. Last one I got was a vintage Steelcase desk w/return in practically mint condition for $40.
unbob
#12 posted 04-18-2015 06:31 AM
I think a Steelcase metal desk could survive a 4 story fall!
unbob
#13 posted 04-18-2015 07:54 AM
I went from a plywood with legs affair, to the HF “cheap instant bench” as a quick fix to getting some things done. Fiddling around with it, I have a better idea on how I want to build a bench suited to the things I like to do.
By the way, the cast Tee handles on both vises, are from a local planning mill from the 1800s. I also made the acme threaded screws and nuts. The guide bars on the end vise are 1 1/8” chrome plated hydraulic rod. All the metal is from the local scrap yard! Adventures in remote living-next day delivery, no.
natenaaron
#14 posted 04-18-2015 05:08 PM
Thanks unbob and others. I was able to get with a coupon and a 20% off. I don’t think they were supposed to do that though, so I bought two because I had some extra coupons. The wife said she thought one would be good as a little extra counter space in the kitchen. I am sure she will change her mind before too long and I will attach the two together. The one for the shop will be braced up. Looks easy enough. That leg vice is sweet. Did you build it?
As for the 2x idea. This was cheaper. After bracing it will will work fine until I can find some good hardwood. I want to make one right but can’t afford it right now.
View mountainaxe's profile
mountainaxe
141 posts in 2411 days
#15 posted 04-18-2015 05:30 PM
Why not just build your own…I built this one (http://www.popularwoodworking.com/projects/toms-torsion-box-workbench) for peanuts and it’s worked out well for me.
-- Jeff, "The things I make may be for others, but how I make them is for me."
