Recess for bolts with forstner bit
Forum topic by PaulHWood posted 04-16-2015 01:24 PM 1205 views 0 times favorited 10 replies Add to Favorites Watch
View PaulHWood's profile
PaulHWood
436 posts in 2280 days
04-16-2015 01:24 PM
Somebody may have a simple answer for this.
You have a hole drilled for a bolt, then decide you want the bolt head recessed, and want to drill the recess with say a forstner bit. Does anyone have a simple way to do this. Also, no drill press.
The only thing I was thinking was using a wood dowel to fill the hole.
Thoughts
-- -Paul, South Carolina Structural Engineer by trade, Crappy Woodworker by choice
10 replies so far
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2396 days
#1 posted 04-16-2015 01:56 PM
Easy to do with the drill press, but since you said that’s not an option, what size is the current hole? If it’s larger than the bearing on a rabbeting bit, you can use a router. Otherwise, your dowel idea sounds like a good option. Might be able to pull it off with a spade bit, but it’d be difficult and the results might not be pretty if this is going to be a visible part.
View bondogaposis's profile
bondogaposis
4769 posts in 2378 days
#2 posted 04-16-2015 01:58 PM
The dowel might work. It always best to drill the big hole first then the little hole for counter sunk bolts.
-- Bondo Gaposis
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1203 days
#3 posted 04-16-2015 02:01 PM
Take a piece of scrap wood and drill a hole with the forstner bit. Place the scrap over the wood where you want to drill the recess and clamp it in place. You will have to center it by eye. Now use the scrap as a guide to hold the forstner bit in place.
View DrDirt's profile
DrDirt
4424 posts in 3769 days
#4 posted 04-16-2015 02:09 PM
+1 WoodNSawdust
4999 posts in 2520 days
#5 posted 04-16-2015 03:48 PM
Yep, what WoodNSawdust said works.
PaulHWood
#6 posted 04-16-2015 04:17 PM
Thanks, thought of this when thinking of using a router, and I don’t know why I wouldn’t just apply the same thinking to a forstner bit
thanks for all the responses
- WoodNSawdust
View jdh122's profile (online now)
jdh122
1018 posts in 2845 days
#7 posted 04-16-2015 04:34 PM
I recently “invented” another way to do this that works well. But it requires a pretty specialized chairmaker’s tool, namely a tapered reamer. I use the reamer to taper the top of the hole just enough so that the largest diameter (right at the surface) is just barely bigger than the forsner bit. Then drill with the forsner – it will self feed on the outside of the hole and drill a perfect recess. I was quite pleased with myself when I came up with this to get me out of a jam, but realize that it won’t work for everyone.
I always feel so stupid when I realize that I’ve drilled the hole before the countersink…
-- Jeremy, in the Acadian forests
View AESamuel's profile
AESamuel
79 posts in 1249 days
#8 posted 04-19-2015 05:35 PM
I’ve got a cone shaped step bit which I use to make the top 1-2mm of the hole the right diameter, then the forstner guides itself down. Its much easier than sticking a piece of wood in there, and more accurate than drilling a hole and then trying to centre it over your other hole.
View BurlyBob's profile
BurlyBob
5555 posts in 2292 days
#9 posted 04-19-2015 07:18 PM
You could use a hole saw to get it started, But honestly WoodNSawdust’s method is the easiest. Just use a piece of wood big enough to clamp it down.
View rwe2156's profile
rwe2156
2965 posts in 1508 days
#10 posted 04-19-2015 09:16 PM
Thoughts
- PaulHWood
Yup!
