Changing belts on JET tablesaw
Forum topic by secretgarden posted 04-16-2015 10:35 AM 847 views 0 times favorited 4 replies Add to Favorites Watch
View secretgarden's profile
secretgarden
18 posts in 1498 days
04-16-2015 10:35 AM
I need assistance in changing out my 20 year old belts on a JET JTAS-10 tablesaw. Any assistance will be apprecitated. Thank You
View rwe2156's profile
rwe2156
2796 posts in 1384 days
#1 posted 04-16-2015 10:49 AM
Tech service at Jet is great if you call they will walk you through it.
I have the same saw I’m guessing you have to loosen and/or remove the motor.
View Yonak's profile
Yonak
986 posts in 1425 days
#2 posted 04-16-2015 03:07 PM
I have changed the belts by just loosening the motor. Be sure to get all the belts from the same lot. Maybe someone else can advise on belt flex.
View MrRon's profile
MrRon
4628 posts in 3147 days
#3 posted 04-16-2015 07:28 PM
The three belts need to be matched and the best way to ensure that is to use Gates, “Power band” belts, available from industrial suppliers. If you try to match them up by using belts from an auto parts store, they won’t match, in that the tension on each belt will not be the same. The result will be power not being transmitted evenly. All three belts will not be working the same.
View MrUnix's profile
MrUnix
6336 posts in 2103 days
#4 posted 04-16-2015 10:38 PM
Loosen motor bolt (don’t remove it). Raise the blade (which lifts the motor). Put a block of wood or similar under the motor to support it. Lower the blade so the motor rests on the wood, taking the tension off the belts. Replace belts, raise blade until it raises the motor and remove the support. Re-tighten motor bolt. Done.
PS: There may be specific instructions on how to tension the belts after installing, so consult your manual.
