oil water hybrid paint
Forum topic by woodworkingdrew posted 04-16-2015 12:32 AM 700 views 0 times favorited 2 replies Add to Favorites Watch
View woodworkingdrew's profile
woodworkingdrew
189 posts in 1479 days
04-16-2015 12:32 AM
I am painting a face frame for a drawer front.
1. is it beneficial to sand between coats of paint?
2. is there a sealer or poly I can apply over the hybrid paint to extend the longevity of the finish?
Thanks- Andrew
-- Andrew, California
2 replies so far
View pjones46's profile
pjones46
997 posts in 2513 days
#1 posted 04-16-2015 12:48 AM
There are many companies that manufacture this type of paint and in different finishes from primers all the way up to high gloss enamels. Most can be over coated with a waterborne poly but you should check with the manufacturer to insure there are no incompatibility issues with their products.
The Waterbased oil enamel are quite durable and I would not think you would need to overcoat it with poly unless it is an extremely high service area.
-- Respectfully, Paul
View Mark Kornell's profile
Mark Kornell
1169 posts in 2401 days
#2 posted 04-16-2015 12:48 AM
1) if you are planning on 2 coats, yes. For 3 coats, you could just sand prior to the 3rd.
2) you probably could put a clear poly or lacquer on top, but not sure why you’d think that necessary. The oil-water hybrid paints are pretty tough on their own. A top coat doesn’t add much, if any, protection. It would also interfere with the ability to do repairs to the finish
-- Mark Kornell, Kornell Wood Design
