Pony Clamp Assembly
Forum topic by hinspeter posted 07-20-2009 01:40 PM 3292 views 0 times favorited 3 replies Add to Favorites Watch
View hinspeter's profile
21 posts in 3176 days
07-20-2009 01:40 PM
Topic tags/keywords: clamp
I bought some new pony pipe clamps and inside the package,along with the clamp is a small coil. It looks like it would go on the pipe but it does not mention it on the package and I can’t figure out where it belongs. I put the clamps together without it and some ot the clamps don’t hold well. I also noticed the metal of the pipes seems softer than the older pipe clamps I have. I purchased both the pipe and clamp at Home Depot,
Any thoughts would be appreciated!
3 replies so far
View jerryz's profile
164 posts in 3215 days
#1 posted 07-20-2009 01:48 PM
aha, that coils is used to protect the thread at the other end of the black pipe.
So if you need to extend your pipe clamp you just get a 3/4” black steel nipple and thread the extension pipe onto the first one. First removing the Thread protector and the slider of course.
Hope this helps….
13598 posts in 3278 days
#2 posted 07-20-2009 01:55 PM
it is a thread cover for a double theaded pipe ,
to keep the slider from coming of ,
and to protect the threads on that end .
you want to use black iron pipe ,
as it is harder than galvinized pipe ,
the galv. gets peeled off ,
and makes it hard to slide the foot .
if you get some threaded couplers , you can put your pipes toghether and make
clamps as long as you got pipe for .
just hand tight is good .
#3 posted 07-20-2009 01:56 PM
Very helpful, indeed! I was trying to figure out if it was suppose to go inside the clamp assembly where the spring is.
