Hinges - Second Attempt!!
Forum topic by littlecope posted 07-20-2009 01:28 AM 2677 views 6 times favorited 19 replies Add to Favorites Watch
View littlecope's profile
littlecope
3071 posts in 3738 days
07-20-2009 01:28 AM
Topic tags/keywords: tip hinges poplar
For those of you who saw it, my first try was a disaster! But I finally got some shop time to try again and thought I’d share the process, it’s as simple as can be…
Started by ripping a strip out of what I’m told is Poplar drawer sides.Hinges- Getting started
Then after a good sanding, to clean up the 70 or 80 odd years of life these things have endured, I cut the strip into four piecesHinges
Two of these pieces are essential only for construction purposes, and I begin using them right away in the drilling of the pivot holesHinges
The two extra pieces give me a nice, flat surface on the bottom. Staggering the clamps also gives it a good sense of balance. I eyeballed these to the center of the pieces, and checked how the holes appeared on the bottom side.
With these drilled correctly I then used a bit of the dowel Hinges
to mark the depth of what will basically be box joints, up to this point.Hinges
Transfer those marks to the “faces”Hinges
then mark the “fingers”Hinges
If you’ll note, I’m using those same “extra” quarters again to keep my rule from falling of these little things as I mark! As far as measurements, I’m a hack, and very seldom measure anything. In this case, the original strip was close enough to nevermind 1 1/4” so the fingers will be 1/4”, three on the fixed end, two on the moving half.
After marking waste from want, I drilled some “maneuvering” holes for the scroll sawHinges
and then it’s off to the scroll saw. Here I’m about halfway through…Hinges
Success!! LOL!! I’ve invented the box joint with a hole through the middle!!Hinges
But we’re talking hinges here, so I take this and round-around the first half of the “swing” using a nail as the temporary pivotHinges
Remove the nail, flip the joint around, and cut the second half of the swing.Hinges
After a little vise and file work to round the whole joint nice, I mark an appropriate “hinge shape”, and drill some undersized pilot holes for the 1/8” doweling I’m going to be using to attach this to the latest box. Hopefully that will reduce the stress inflicted on these small partsHinges
And now the most critical step of all, the one I neglected the first time around which caused this whole redo in the first place! The “moving” half of the hinge needs to be enlarged a little, so it’s free-turningHinges
With that done, I use those ever-present extra pieces to hand-clamp the hinges together while I tap in the pinsHinges
And there you have them!Hinges Trim off the excess, some final clean up and sanding, and these are ready to be attached. Since these lie flat on the back when the box is closed, and only open a little more than 90 degrees they should work out pretty well for box tops. :-)
19 replies so far
View odie's profile
odie
1691 posts in 4076 days
#1 posted 07-20-2009 02:23 AM
Thanks for the information Micheal. I’ve tried these too, but I used the Incra system. I found that they stretched patience to the max.
View Dan'um Style's profile
Dan'um Style
14179 posts in 4219 days
#2 posted 07-20-2009 02:42 AM
good post … well done, need to try making my own hinges someday
littlecope
#3 posted 07-20-2009 02:57 AM
Are We having Fun yet?! Actually Odie, I was hoping that these were going to take a lot longer, but sadly only got to spend about 3 hrs. in “The Lab” today, and most of that was taking pictures (sigh). Of course the Lab is so small, I only need to turn to be at the next station. .)
View noblevfd's profile
noblevfd
48 posts in 3693 days
#4 posted 07-20-2009 03:00 AM
good job I love the pics with the method it makes it seem doable when it is done like that another of the 1000 things I’d like to try thanks noblevfd God bless
16281 posts in 4454 days
#5 posted 07-20-2009 03:14 AM
Nice step by step tutorial, Michael. It still looks too much like a disaster waiting to happen in my hands, though.
View cabinetmaster's profile
cabinetmaster
10874 posts in 3794 days
#6 posted 07-20-2009 03:22 AM
Have never tried wood hinges but just may have to try sometime.
View lew's profile
lew
12495 posts in 3991 days
#7 posted 07-20-2009 04:35 AM
Thanks for the lesson, Mike.
That looks like a Bridgewood Scroll Saw.
View lew's profile
lew
#8 posted 07-20-2009 04:36 AM
View PurpLev's profile
PurpLev
8548 posts in 3884 days
#9 posted 07-20-2009 04:51 AM
these look great! thanks for the post, this is a good step by step tutorial, and easy to follow
View bowyer's profile
bowyer
340 posts in 3632 days
#10 posted 07-20-2009 05:13 AM
Nice looking hinges. The step by step is easy to follow and understand and thanks for the heads up about enlargeing the holes on the moving portion of the hinge. I would have found that out the same way you did.
Rick
-- If at first you don't succeed...Don't try skydiving
13641 posts in 3577 days
#11 posted 07-20-2009 05:58 AM
great mike ,
clean , concise , and to the point !
a good share .
View Ben Kahmann's profile
Ben Kahmann
231 posts in 3508 days
#12 posted 07-21-2009 02:51 AM
Sweet!
-- Ben Kahmann Dayton, OH
View bobthebuilder647's profile
bobthebuilder647
128 posts in 3488 days
#13 posted 07-21-2009 03:32 AM
WOW! I never thought of wood hinges. I hope I can try that soon.
Thanks
-- Rick, Pa. Courage is what it takes to stand up and speak; courage is also what it takes to sit down and listen.
View jim1953's profile
jim1953
2736 posts in 4078 days
#14 posted 07-21-2009 04:00 AM
Great Lookin Job
-- Jim, Kentucky
View bobmacl12's profile
bobmacl12
5 posts in 3457 days
#15 posted 08-07-2009 11:22 AM
Nice job and well-presented. I have never made wooden hinges but once I complete a few projects I am on I might have a go at them. Thanks, Bob.
-- Bob
