| Forum topic by ghazard | posted 132 days ago | 508 views | 0 times favorited | 15 replies | ![]() |
132 days ago |
Topic tags/keywords: tearout Hi all…I’m building a box using Mahogany with Paduk accents. I was trimming the paduk spines flush with a flush trim bit on the router table and on the last one got a blowout (see pics below). What do you suggest is the best way to fix this corner? I am considering routing out the corner again to remove all the paduk then re-gluing a new piece in. But a question arises…would I have to take the slot deeper (ie bigger) to expose new mahogany or could I come right up to the glue interface between the two pieces and re-glue on top of that? THe other thought i had was to use a chamfer bit and take off just the corner then glue on a piece and trim it back into a square corner. Any and all suggestions welcome. Thanks! Greg
-- If, in your life, you attain the means to help; you incur the responsibility to act. |
132 days ago |
Cut it out completely and re-do. You could just leave a very small sliver of paduk. I think you would be hard pressed to notice it. -- Gary, East TX -- The longest journey begins with a single step. |
132 days ago |
Hey Greg I guess was posting the same time GaryK was -- Jim from Heirloom Woodshop, custom furniture ,maker, woodworking school, heirloomwoodshop.com |
132 days ago |
You don’t really have any other choice than to do what gary suggests it would never be right otherwise and not worth the effort of saving this bad piece Alistair -- excuse my typing as I have a form of parkinsons disease |
132 days ago |
Looks like you could 45 your corners and get rid of the tearout, but it would change the look of your box, maybe not bad. |
132 days ago |
ditto on above , -- david ,new mexico ,allheart |
132 days ago |
This is why I love woodworking. Learning how to fix the mistakes and the little problems that can arise in any project. It has given me some well needed patience and perseverence. I agree with Gary and would replace it all together. -- My job is to give my kids things to discuss with their therapist....medic20447@gmail.com |
132 days ago |
I’m with Gary K and a1Jim. It happens to all of us sooner or later. -- Todd A. Clippinger, Montana, http://amcraftsman.com |
132 days ago |
Ok, thanks. Looks like cutting it out and regluing is the way to go. Bentlyj, I had thought about that. But I decided that, since this is my first attempt at a box assembly like this, I would take the opportunity to learn how to make a fix when something like this happens… I will definitely pick my next piece closely for grain. Thanks everyone! Greg -- If, in your life, you attain the means to help; you incur the responsibility to act. |
132 days ago |
Greg – It’s not so much a matter of choosing your grain, but cutting it using a method that won’t cause it to split. Since you are using a router table you want to cut it in the proper direction. Don’t cut in the direction that makes the router bit “scoop” out against the grain, but “push” it down. Basically cut with the grain. -- Gary, East TX -- The longest journey begins with a single step. |
132 days ago |
Gary, What would you do it this case, run it through the router backwards very slowlY? -- Debt is nothing more than the 21st Century's form of slavery. |
132 days ago |
I’ve been in the shop…although not fixing the corner…I’ll do that next weekend…I moved onto shaping some 1/8” thick paduk for some inlay on the lid. It is very delecate to work with. The grain seems not to be very strong. This is my first time working with Paduk and also working with stock this thin…is that typical of paduk? -- If, in your life, you attain the means to help; you incur the responsibility to act. |
131 days ago |
Gary, it sounds like climb cutting is what you are describing…is that right? I will get a chance to fix the corner in a few days, Until then…I’ll take all the help I can get. Thanks, Greg -- If, in your life, you attain the means to help; you incur the responsibility to act. |
130 days ago |
Hi Greg, Have you tried a solid carbide down-cut spiral router bit. It pushes the chip toward the work piece and produces a MUCH smoother cut. Just know that they don’t clear chips as well as an up-cut spiral, and are not as good on deep cuts like mortises. Like many of those suggestions above, I’d re-cut back to the glue line and replace the whole piece. Good Luck. -- dust control |
130 days ago |
For TopamaxSurvivor. All he has to do is turn the box around and over and run it through the router table the other direction….which will be with the grain. Making several shallower cuts would probably also work. -- Les B, Oregon |
130 days ago |
I suppose if the box ever gets dropped it’s trouble anyway you look at it.You could also round of the four ends with a large disc sandet or belt sander but as said this might weaken the structure.Alistair -- excuse my typing as I have a form of parkinsons disease |
| Forum | Topics |
Woodworking Skill Share
2928 |
3961 |
257 |
955 |
226 |
Woodworking Trade & Swap
622 |
Coffee Lounge
2398 |
LumberJocks.com Site Feedback
524 |
