Rebuilding a Craftsman 113.29991. Alignment Question
Forum topic by rstandi posted 04-13-2015 01:53 PM 958 views 0 times favorited 2 replies Add to Favorites Watch
View rstandi's profile
rstandi
2 posts in 1048 days
04-13-2015 01:53 PM
Hi, All,
Rebuilding a Craftsman 113.29991 Table saw. I got the PALS system. The trunions are rounded on this saw. Will the PALS work with out filing them flat? and if not, what is the best way to smooth them?
Thanks
Rod
2 replies so far
View toolie's profile
toolie
2109 posts in 2536 days
#1 posted 04-14-2015 02:18 AM
Ditch the pals. Just clamp a cheap dial gauge to the head of ad miter gauge. Remove all slop from the miter bar. Aligning the blade to a miter slot, following the OM instructions should take 15 minutes, tops.
View EEngineer's profile
EEngineer
1092 posts in 3521 days
#2 posted 04-15-2015 09:17 AM
Agreed. PAL’s are a nice idea but I didn’t discover them until after I had aligned my saw. Mine took about 1/2 hour – I don’t think PAL’s would have sped that up.
I spent more time than that constructing this to help with the alignment:
I still use it to check alignment once in a while – going on 7 years now and I haven’t had to realign it! PAL’s seem like an expensive investment for something you will use so seldom.
