Is this due to a dull bandsaw blade? OR?
Forum topic by DocSavage45 posted 04-12-2015 11:08 PM 1412 views 0 times favorited 24 replies Add to Favorites Watch
View DocSavage45's profile
DocSavage45
8559 posts in 2843 days
04-12-2015 11:08 PM
Topic tags/keywords: question bandsaw milling
Thought I’d try the saw with the Olsen 1/2 inch 3 tpi blade I have been using before switching to the 5/8ths blade ( woodmiser type) to cut some elm that is a hearty tree that won’t die.
What is the largest diameter and length you cut?
I believe I had adequate tension but the blade drifted significantly to the sliced side. Starting at 1 inch it varied through the cut getting narrowwer.
tried a narrower maple log about 32 inches long 6 inches in diameter, and the cut really drifted. And the machine bogged down?
I’m guessing the blade has gotten duller? But seems sharp to the touch.
Suggestions welcome.
Thanks
Tom
-- Cau Haus Designs, Thomas J. Tieffenbacher
24 replies so far
View Andre's profile
Andre
1839 posts in 1807 days
#1 posted 04-12-2015 11:19 PM
Sounds like blade drift or not enough tension ? On my old Delta BS everything needs to be perfect to get nice resaw cuts!( Resawing 6” Birch)
View tyvekboy's profile
tyvekboy
1752 posts in 3014 days
#2 posted 04-12-2015 11:23 PM
My guess is the board after it was cut was relieving stress and pinching the blade. If a blade bogs down, stop the saw and wedge the saw kerf after the blade to open the kerf up. That may solve the problem.
This would also apply to sawing wood on a table saw. Once I was cutting a piece of hickory on my 3hp cabinet saw and the kerf started closing up after it was cut so I stopped the saw, added a wedge, and continued cutting.
-- Tyvekboy -- Marietta, GA ………….. one can never be too organized
View MrUnix's profile
MrUnix
6716 posts in 2199 days
#3 posted 04-12-2015 11:33 PM
A dull blade can cause it.. but I’d try adjusting your tracking first (that’s what it’s for!).
View distrbd's profile
distrbd
2252 posts in 2447 days
#4 posted 04-12-2015 11:44 PM
Mr unix said it,I would also check the tires ,loose(or badly worn/cracked) tires can cause tracking problems.
-- Ken from Ontario, Canada
View gfadvm's profile
gfadvm
14940 posts in 2691 days
#5 posted 04-12-2015 11:59 PM
Several thoughts: cutting green/wet wood requires deep gullets to clear the sawdust, try cutting a dry pine board and see if you still have the same degree of blade drift, feeding stock too fast can also cause drift, I’m assuming you have tracked your blade where the bottom of the gullets are centered on the wheel?
HillbillyShooter
5811 posts in 2293 days
#6 posted 04-13-2015 12:18 AM
When I’ve had trouble with blade drift, it turned out to be the blade was dull despite feeling sharp and not having been used that much (at least I thought it hadn’t). 6” inch re-sawing takes a lot out of a bandsaw blade when it’s on a 14” bandsaw.
DocSavage45
#7 posted 04-13-2015 12:21 AM
Tightened the tension.Had cut three pieces previously. Maple log, walnut log and ceder. No drift. I will check the lower wheel. Tires are like new. The blade is hook tooth 3 tpi. I may have run it against the screws anchoring it to the jig in my last run?
don’t know if I mentioned getting bogged down in middle of the cut on the maple. High pitch sounds and I will look into the tension issue.
Tried a plece of the maple vs. the elm that I was cutting. DDrrift bad in both cuts?
Thanks Andy, Ken, Brad, Tyvekboy, rad457
DocSavage45
#8 posted 04-13-2015 12:24 AM
John,
I was running a test to check feed and cut before changing to the Woodmiser clone. Ran out of time. Will take these great suggestions to the shop tomorrow. :<)
gfadvm
#9 posted 04-13-2015 12:24 AM
If your blade touches metal while running, it is toast! It may still cut, but not straight.
DocSavage45
#10 posted 04-13-2015 12:33 AM
Sounds like a shared learning experience. LOL!
View Blackie_'s profile
Blackie_
4883 posts in 2513 days
#11 posted 04-13-2015 12:48 AM
Tom invest into a metal finder, I’ve ran through a nail and barbed wire cutting through logs before.
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
DocSavage45
#12 posted 04-13-2015 12:55 AM
Randy,
This was the screw I used to anchor the log to the jig. an “Oh Dah!” moment?
And I will remember to use my metal wand just for precaution
View Monte Pittman's profile
Monte Pittman
29233 posts in 2339 days
#13 posted 04-13-2015 01:49 AM
My thought goes to tension on the blade if it’s sharp. Also, elm is not an easy wood to cut. It will give you fits.
DocSavage45
#14 posted 04-13-2015 02:11 AM
Thanks Monte,
It seems more dense. Like me? LOL!
18208 posts in 1857 days
#15 posted 04-13-2015 02:16 AM
I’m thinking like Andy, if you touched metal on one side it will cut away from that side now.
