Why does my GRR-RIPPER not grip?
Forum topic by WhiskeyCreek posted 04-12-2015 05:23 PM 1549 views 0 times favorited 7 replies Add to Favorites Watch
View WhiskeyCreek's profile
WhiskeyCreek
17 posts in 1153 days
04-12-2015 05:23 PM
Topic tags/keywords: grr-ripper push block safety question
I have recently bought a micro jig gripper for small cuts on the table saw and re-sawing. It was not a cheap push block and not first on my list, but I like my fingers and want to be as safe as I can. The system works well and will keep you very safe, but mine does not seem to grip. It seems to slip forward on the wood when I am pushing a piece through the table saw. If I push down hard with both hands on the back end it seems to work but that shifts my weight and creates a very unsafe working position. I have tried cleaning off the saw dust every time and changing where I put pressure on the block and nothing has worked. I shouldn’t have to work extra hard for a push block to push. Has anybody else found this about the gripper? Does anybody know of a way to make my gripper grip?
-- Whiskey Creek Woodmill & Co.
7 replies so far
View Woodendeavor's profile
Woodendeavor
276 posts in 2607 days
#1 posted 04-12-2015 05:31 PM
Do you have a hard time feeding stock through with out the gripper? It sounds to me like you need to work on the saw table
View johnstoneb's profile
johnstoneb
2915 posts in 2173 days
#2 posted 04-12-2015 05:44 PM
clean the gipper surfaces with lacquer thinner and they make a little block that fits on the rear of the Gripper that will drop down and catrch the rear of the wood to help push thru. and wax your table.
-- Bruce, Boise, ID
View waho6o9's profile (online now)
waho6o9
8191 posts in 2577 days
#3 posted 04-12-2015 05:45 PM
Maybe wax the table?
View bonesbr549's profile
bonesbr549
1549 posts in 3067 days
#4 posted 04-12-2015 06:15 PM
Asothers have said what your grippers with cleaner also make sure you have no dust on your wood. If you’re stillhaving problems make sure your tables waxed good luck.
View TimberMagic's profile
TimberMagic
114 posts in 1179 days
#5 posted 04-12-2015 06:17 PM
I’ve found that some woods, like oak, need a little extra “push”. Use the sacrificial push plate that mounts on the back of the GRR-Ripper.
I’ve only washed the pads with soapy water. I’d be wary about using a strong solvent like lacquer thinner, without checking the manual. It might melt the material. I think they recommend rubbing alcohol or soapy water, I just do not recall, since soapy water has always worked for me.
-- Lee
View csnyderdvm's profile
csnyderdvm
20 posts in 1739 days
#6 posted 04-13-2015 02:41 AM
yes, they make “gravity heels” now that are more replaceable pieces of the same yellow, high density plastic. the heels are spring loaded and drop down and can be secured in place. One package buys you 6 (I think) and they market them in the way that you can use them as sacrificial pieces for router table pieces and all. I’ve only had limited time with mine but I like them as the alternative to using the push block with the auto drop down anti-gravity heels that aren’t replaceable.
waho6o9
#7 posted 04-14-2015 02:32 AM
When the plastic tabs in the back wear down I make em out of plywood.
