Jointing wide boards method - how good are the results?
Forum topic by bbasiaga posted 04-11-2015 09:29 PM 1284 views 2 times favorited 15 replies Add to Favorites Watch
View bbasiaga's profile
bbasiaga
1242 posts in 2236 days
04-11-2015 09:29 PM
Topic tags/keywords: jointer
I was pointed to a method to joint boards wider than your jointer by some other ‘Jocks. This is the method I am talking about:
https://www.youtube.com/watch?v=casDTQ0y60Y
For those of you using this method, how well does it work out? Good enough to make table tops without tons of scraping or sanding?
I’m agonizing over a jointer purchase. I really see the value in the width of an 8” jointer, but the more I look at it, the more afraid I am that I will be overbuying for the shop space I have. Wish someone made a 50” long 8” jointer…..
If I could get away with this method reliably, a nice 6” jointer would save me space and some money, even if I upgraded to a paralellogram or helix cutter. But if this method is just frustrating and hit or miss, I will take a harder look at rearranging things to get an 8” jointer in place.
-Brian
15 replies so far
View Shadowrider's profile
Shadowrider
183 posts in 1450 days
#1 posted 04-11-2015 10:09 PM
I’ve been wondering the same thing myself. For me I think I can make this method work for the money and space savings. I’m pretty sure I’ll just get one of the Grizzly 6” jointers and be happy with the savings to buy a few more clamps.
View DKV's profile
DKV
3940 posts in 2745 days
#2 posted 04-11-2015 11:11 PM
bb, do you make tabletops for a living?
-- This is a Troll Free zone.
View SPalm's profile
SPalm
5326 posts in 4123 days
#3 posted 04-12-2015 12:12 AM
Hey,
I have a Powermatic 6 inch jointer that I put a helical head in. I really like it, but an eight inch would be nice. I just could not justify the money back then. A lot of boards come a bit larger than six inches.
Anyway, I have used that technique a lot and it works ok. A bit of futzing around, but it works. Kind of scary without the blade guard installed. I use an L shaped wooden bracket that is clamped to the fence and hides the blade. The workpiece goes under it. I often use a long strip of six inch wide Masonite that I double sticky tape to the board for the leveler. You can reuse it a bunch of times before changing the tape.
Steve
-- -- I'm no rocket surgeon
View BorkBob's profile
BorkBob
127 posts in 2933 days
#4 posted 04-12-2015 12:17 AM
I have an 8” jointer and a 15” planer. I use the jointer to get the boards flat; they don’t have to be pretty.
For boards wider than my jointer, I joint with the cupped side down. I make a couple passes and turn the board end for end. A couple more passes and turn it again. I do this until the board shows “clean” down both outer edges which tells me the board will stay flat when planed. The raised strip in one edge doesn’t bother me. A couple or three passes through the planer and I flip the board and remove the raised strip.
-- Please Pray for Our Troops / Semper Fi / Bob Ross / www.theborkstore.com
View gfadvm's profile
gfadvm
14940 posts in 2931 days
#5 posted 04-12-2015 12:21 AM
Brian, That is the method I use. The sandpaper (or a shallow cleat) on your sled is important to keep your workpiece from moving backwards off the sled. Quick and simple. Looking at those spinning blades with no guard is a little intimidating at first.
View WillliamMSP's profile
WillliamMSP
1084 posts in 1845 days
#6 posted 04-12-2015 12:34 AM
Since the method in question relies on a planer already, why not one of the planer sleds? (such as http://www.finewoodworking.com/workshop/video/a-planer-sled-for-milling-lumber.aspx)
-- Practice makes less sucky. (Bill, Minneapolis, MN)
gfadvm
#7 posted 04-12-2015 12:39 AM
Bill, I have built a planer sled as well and the jointer method is a LOT quicker. I use my planer sled for stock that is too wide for the jointer method.
View bonesbr549's profile
bonesbr549
1579 posts in 3308 days
#8 posted 04-12-2015 02:06 AM
That looks very interesting. Back in the days before I got my 12 inch planer, i used winding sticks and a hand plane. It was fast and worked like a charm
View AlaskaGuy's profile
AlaskaGuy
5002 posts in 2550 days
#9 posted 04-12-2015 02:20 AM
Just get a bigger hand plane.
https://www.youtube.com/watch?feature=player_detailpage&v=Wl42bLPiCpA
SPalm
#10 posted 04-12-2015 02:23 AM
Planer sleds work ok. Quite a lot of futzing to stabilize the board though. And you have to store a large sled. You can find a few on LJs.
Another way is to make a router sled that makes two grooves that will then hold two reference sticks for the ride through the planer.
http://lumberjocks.com/topics/1992
Steve
bbasiaga
#11 posted 04-12-2015 01:41 PM
Thanks guys.
No, I am not a professional, but if its true that you can’t buy tools unless you need them for a living, then please delete this post before my wife sees it! I have a good thing going and don’t want to ruin it! :)
I have researched the planer sleds, but I just don’t see that as something I’m going to be happy with. Looks like a lot of tinkering, opportunities for stuff to move, etc. The rouer/slot method I looked at pretty hard too, but by the time you do that in a 4/4 board you may not have much left to work with once its all flat. As far as hand planes, well I have something of a Tim Taylor streak in me coupled with the inexplicable inability to sharpen anything.
I need to take a harder look in the shop and see if I can work the 8” jointer in there. I would really like it, but at least if it doesn’t fit it seems you can get good results with this method.
-Brian
BorkBob
#12 posted 04-12-2015 01:51 PM
My shop is only 20×20. I put my 8” jointer on a furniture dolly from Harbor Freight http://www.harborfreight.com/30-in-x-19-in-1000-lb-capacity-hardwood-dolly-60496.html
I’m tall so the added height actually helps my bad back. The jointer has its own tripod casters but this dolly allows me to move sideways to store the beast against the shop wall.
bbasiaga
#13 posted 04-12-2015 02:00 PM
I actually just bought two of those to help me get the boxes from the curb up to my garage! There was a coupon in a magazine I had for $8.99 each so I figured what the heck. Hadn’t considered using them permanently!
-Brian
117420 posts in 3818 days
#14 posted 04-12-2015 02:07 PM
Tim covered this subject very well some time ago on LJs
http://lumberjocks.com/tenontim/blog/26637
5242 posts in 2734 days
#15 posted 04-12-2015 03:10 PM
Those times I have to joint boards wider than my jointer, I do (sort of) what BorkBob suggested. I’ll go through the jointer, I usually set the fence to do just slightly more than 1/2 of the board. Then flip it end for end and do the other half. I don’t do this a lot, but the times I have it has worked very well.
