Built-in Bookshelf Question
Forum topic by MrsN posted 04-10-2015 04:05 PM 908 views 0 times favorited 5 replies Add to Favorites Watch
View MrsN's profile
MrsN
987 posts in 3763 days
04-10-2015 04:05 PM
My house is heated with electric baseboard heaters, I want to build a wall of bookshelves but am not quite sure what to do about the heaters.
Can I make the base of the bookshelf a little wider then “normal” and mount the baseboard heaters to the front?
5 replies so far
View jumbojack's profile
jumbojack
1685 posts in 2861 days
#1 posted 04-10-2015 04:12 PM
Sure you can. My only concern would be the contents of the bookshelf getting more heat than they would like. Further it will require rewiring the baseboard heaters or at least splicing in additional wire.
View dhazelton's profile
dhazelton
2805 posts in 2534 days
#2 posted 04-10-2015 04:26 PM
Yes. But code says you aren’t supposed to have a junction box buried where you can’t access it so you might have to leave the bottom shelf loose so it can removed easily or a longer piece of wire from the line side installed from the panel.
View crank49's profile
crank49
4032 posts in 3208 days
#3 posted 04-10-2015 07:01 PM
You can also get base board heaters with lower density elements.
Reduces the heat output but sometimes solves problems with heat sensitivity of adjacent materials.
View bbasiaga's profile
bbasiaga
1242 posts in 2232 days
#4 posted 04-10-2015 07:31 PM
Start the bookshelves above the heaters? Hang them off a french cleat system maybe….
Maybe build out a little grill system under them so that the heat still flows readily out, but it still looks like part of the bookshelf.
-Brian
View exelectrician's profile
exelectrician
2328 posts in 2665 days
#5 posted 04-10-2015 08:43 PM
Use common sense.
-- Love thy neighbour as thyself
