Dremel router bits
Forum topic by Sanderguy777 posted 04-10-2015 03:47 AM 1187 views 1 time favorited 6 replies Add to Favorites Watch
View Sanderguy777's profile
Sanderguy777
189 posts in 1443 days
04-10-2015 03:47 AM
Topic tags/keywords: question carving tool router carving shaping
Anybody know of some cheap 1/8” shaft router bits that would work in a Dremel tool? I am getting the plunge router accessory so I need some bits… But I don’t want to break the bank either. The Dremel brand bits are like $30 bucks for six. For that kind of money I could get a set of real router bits!
I have some high speed cutters, would they work as bits or would they burn the wood?
Thanks
-- Marc Spagnuolo (standing in front of clamp wall): I think I need a few more . Me (owner of at least 8 clamps):.....?
View jshroyer's profile
jshroyer
80 posts in 1899 days
#1 posted 04-10-2015 12:28 PM
So i am known as a bit of a dremel nut. At one point i owned 4 dremel tools. In college i was in a club that would use them a lot and we would go through the bits a lot because the tools would fall off the table and break the tools or just wear out. I found this website below. I mostly used reinforced cut off wheels and sanding drums from them. They dont last as long as the dremel brand but if you dont mind changing them a bit more often its cheaper in the long run. I think its worth it because instead of taking just the right depth of cut and going slow i go fast and take big cuts but they dont last as long. takes about the same amount of time.
http://www.widgetsupply.com/category/dremel.html
-- http://semiww.org/
View CB_Cohick's profile
CB_Cohick
487 posts in 1492 days
#2 posted 04-10-2015 01:04 PM
- jshroyer
Thanks for this, jshroyer.
-- Chris - Would work, but I'm too busy reading about woodwork.
View timbertailor's profile
timbertailor
1594 posts in 1665 days
#3 posted 04-10-2015 02:25 PM
I am not sure about their prices but you may also want to try Stewart McDonald
Let us know what you think.
Sanderguy777
#4 posted 04-10-2015 09:31 PM
Thanks, I think that Widget Supply is where I’ll get them. McDonald is a bit over my price point, but their jigs snd attachments look very cool and if I ever want my Dremel to look like a Lie Nielson, I will go there!!
View MrUnix's profile
MrUnix
7114 posts in 2440 days
#5 posted 04-10-2015 10:47 PM
For the cut off wheels, go with the fiberglass reinforced ones.. they last WAY longer. I tried cutting out some seat pedestals in a VW once and went through a dozen of the normal ones and about a half a dozen of the ‘premium’ ones on just one pedestal. I got tired of changing them out every couple of minutes (or having them break), so I bit the bullet and bought a 5 pack of the fiberglass reinforced ones. It only took one to cut out the other pedestal with more than 3/4 of the wheel still left when I was done. I used that disc for almost another year before having to replace it and am only on my second one now. YMMV.
Sanderguy777
#6 posted 04-11-2015 03:23 AM
Why didn’t you use an angle grinder? Or did that not fit in the space?
I used my Dremel for a while on stuff like pipes and things, but then I got an angle grinder….. I hardly touch the Dremel for cutting stuff anymore.
I have the fiberglass wheels, but they are not the EZ-Lock kind. They are the ones that use the screw mandrel thing. I like them better than the EZ-Lock ones cause you get more cutting depth and they are cheaper, too.
I expect to get it in about a month or two cause it has to get shipped, but I got an imitation Multi Max tool for $15 at Woodcraft the other week. I have never used one but I think that is a really cool tool that is very versatile. Besides, who can complain about a 15 dollar tool that can do anything?
