Curly Red Oak filling
Forum topic by ahock posted 07-15-2009 01:01 AM 1384 views 0 times favorited 6 replies Add to Favorites Watch
View ahock's profile
ahock
102 posts in 3560 days
07-15-2009 01:01 AM
Topic tags/keywords: curly red oak filler planer
Hey Guys, I’m making a 16×20 picture frame out of curly red oak and padauk. I ran the oak through a thickness planer today to bring it down to about 1/16 over my final thickness, and lo and behold…GAH! on the final pass some grain pocks out (for lack of knowing the real term). So now on the front of my frame I have 5 pocks that are about the diameter of a pencil eraser, and just over 1/16” deep. So, now that I am past being able to plane them down anymore what is best to fill these with? Mix glue and sawdust? Is there a filler out there that would be close to an invisible patch? Other ideas? It’s going to be finished with a coat of dewaxed shellac, and then 3-4 coats of GF Arm-R-Seal.
Oh, and I was hoping to have this ready for finishing by the end of the night. :)
-- Andy, PA ~Finding satisfaction in creation
View tenontim's profile
tenontim
2131 posts in 3980 days
#1 posted 07-15-2009 01:34 AM
There’s nothing that’s going to be invisible. Famowood makes a red oak filler. It matches red oak ply pretty good and may come close to the flake in your lumber. You may have to try a stain or dye on it. Good luck.
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3522 days
#2 posted 07-15-2009 05:33 PM
No filler is really going to be acceptable, especially if it’s on the face. Figured wood of any kind is almost always a problem with a planer, even with sharp knives. I try to compensate for that ahead of time by leaving it thick, and sanding down the rest. In fact, in my door shop, certain woods we don’t even try to plane because of that issue. We use a wide belt sander, (which most people don’t have access to) Hand planes and scrapers are also a good choice.
Can you sacrifice a little thickness and sand or hand plane at this point? I know this is not what you wanted to hear, but patches usually look like——-patches.
-- http://shepherdtoolandsupply.com/
13641 posts in 3577 days
#3 posted 07-15-2009 05:43 PM
if they are all close to the same place in width of the board ,
could you inlay a strip of padouk and call it a design line ?
i always plane the back ,
when i find a good face ,
just because of this problem .
ahock
#4 posted 07-16-2009 12:22 AM
Thanks guys for the ideas, I picked up some famowood today and will try it on a piece of scrap to see how it looks. Kent, the only sander I have that could take off 1/16 on everything with less than a weeks work is my belt sander and I am not good at keeping an even thickness with it. I’ve been scraping but am about as thin as I feel I can spare now. I had thought about the inlay strip Patron, but I would have 3, 3/8” wide strips on one 2 1/4” wide piece; a little more than I wanted. I’ll see here in the shop tonight what I can figure out, I really want to at least start finishing tonight!
View BobLemon's profile
BobLemon
8 posts in 3474 days
#5 posted 07-16-2009 01:24 AM
ahock, it can be patched. If you have a carver’s gouge, scoop out a little depression, then overlay/inlay the hole with the chip carved out of a matching piece of scrap. Use hide glue plus clamp the inlay by laying a piece of thick rubber over the patch, then clamp. When dry sand or scrape flat. The excess glue can then be washed away carefully.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3716 days
#6 posted 07-16-2009 03:48 AM
Another tip you could try is to fill the divits with a good wood filler. Let it dry and sand it flush with the wood. Then take a sharp utility knife and put some very fine cuts across the filler and a bit beyond into the wood piece in each direction (top to bottom) and in the same direction as the wood grain and try to simulate the wood grain pattern. Then take a little darker stain mix it with the filler, and fill the knife cuts. Once set up, sand lightly and stain the entire piece with your chosen stain. I have used this on a couple of projects over the years and it is very difficult to see the fill. This will test your artistry :-)
-- Wayne - Plymouth MN
