Circular saw not working?
Forum topic by chetrog posted 04-10-2015 01:41 AM 1034 views 0 times favorited 8 replies Add to Favorites Watch
View chetrog's profile
chetrog
84 posts in 1433 days
04-10-2015 01:41 AM
I had a stroke years ago, and sometimes I don’t have the best ways to explain stuff, but I’m hoping somebody could help me with a question about a circular saw. I was using my my circular saw and it all of a sudden it doesn’t work. I was cutting a 4×6 pressure treated board. I cut the board on one side “the blade was to short to cut it in on cut” and flipped the board over to cut the other side and the saw work turn on anymore. The saw sounded good and I was cutting slow. The circular saw uses a light work and uses a red inferred beam that i can still see, so the outlet is still giving power to the saw. Also the blade is still movable, it isn’t being blocked buy wood or the motor doesn’t appear to be seized. Is there anything I can use to try. I assume there isn’t a breaker on a saw, but just want to check if there is something i can check. I have the saw about 6 months, but have only used it about 8 times. I don’t want to buy a new one. Thanks for your time.
-- I had a stroke a few years back, and sometimes the words dont come out as well as I would like.
8 replies so far
View TheFridge's profile (online now)
TheFridge
9255 posts in 1455 days
#1 posted 04-10-2015 01:44 AM
Have you tried spinning the blade by hand then trying it? Have you checked the brushes?
MrUnix
6612 posts in 2168 days
#2 posted 04-10-2015 01:46 AM
What model saw and is it still under warranty? Sounds like a bad switch… probably too new for the brushes to be toast.
TheFridge
#3 posted 04-10-2015 01:53 AM
Durp. Forgot about the switch.
View Crank50's profile
Crank50
173 posts in 1546 days
#4 posted 04-10-2015 01:54 AM
I had that happen to my old Skil brand circular saw.
Took it apart and there was a bunch of saw dust packed up in the switch.
Gave it a good cleaning, put it back together, and it’s good as new.
View exelectrician's profile
exelectrician
2327 posts in 2397 days
#5 posted 04-10-2015 02:01 AM
Look on the motor sometimes there is a red button near where the cord enters the motor give it a positive push, this will reset the overload and you are back sawing.
-- Love thy neighbour as thyself
View AlaskaGuy's profile
AlaskaGuy
4051 posts in 2278 days
#6 posted 04-10-2015 03:42 AM
Check your extension cord. Make sure the power from the outlet is making it all the way to the saw. Maybe a broken wire in the cord
chetrog
#7 posted 04-12-2015 01:30 AM
Thanks for the suggestions guys. I will be taking it apart tomorrow.
View Ghidrah's profile
Ghidrah
667 posts in 1192 days
#8 posted 04-12-2015 02:37 AM
I loved my Skilsaws , but they had an issue with their triggers dying I had the same 2 8” skils for 13 to 15yrs and I got to the point where I bought 4 triggers at a time. Those saws could cut all day every day they had the best toughest beds that didn’t bend from falling off a work table to the ground and they were heavy enough to keep all the sissies from using them.
-- I meant to do that!
