| Forum topic by Brad | posted 135 days ago | 1116 views | 0 times favorited | 14 replies | ![]() |
135 days ago |
Topic tags/keywords: tip question joining drill-driver So I’m building Norms Deluxe Router station and while building the fence portion I’m having to drive screws into MDF. Now of course I pre-drilled all my holes but for some damn reason the MDF keeps splitting! Any suggestions guys? I went larger on my drill bit but I’m almost drilling out the size of the threads at this point. I spent a ton of time cutting all the MDF and had one 3”x3” block just split right in two. - Ugh -Brad -- Great Coffee= 8oz strong coffee, 1tbsp brown sugar, 1tbsp 1/2&1/2, 1 heaping teaspoon mahoganny |
135 days ago |
I have had this problem as well and solved it by using a clamp when putting screws into the end grain. This seems to stop the splitting and allows the screw to bite and hold. |
135 days ago |
Confirmat screws work well for MDF. There is a special tapered drill bit to match the profile of the screws. I think McFeelys, Rockler of Woodcraft sell them. |
135 days ago |
I agree with Vincent. I recently put together a bookcase out of MDF and used Confirmat screws with great results. You can check my projects page for the bookcase, but I bet I put in ~40 screws with only one causing splitting. I got mine from McFeely’s and they offer a kit that comes with the needed stepped drill bit, screws, and plasitc caps. -- Derrek L. |
135 days ago |
If you must screw MDF, Vincent and Derrk are right on. -- Kent Shepherd * The goal is-----More Tools! |
135 days ago |
I agree with vince and Kent -- Jim from Heirloom Woodshop Southern Oregon |
135 days ago |
I’ll second Kent. although confirmat are the way to go with screwing MDF. I think for the long run – you’re better off finding another solution to joint these, or use a different material – esp. since this is for the fence for your router table which should stay true for the long run. -- When in doubt - There is no doubt - Go the safer route. |
135 days ago |
My experience with MDF is similar to the comments above. Particle board is a bit stronger but still wont take much twisting without breaking the fasteners loose. Bob -- A mind, like a home, is furnished by its owner |
135 days ago |
You could predrill the holes, then take the pieces apart and run a countersink in the holes at the faying faces. -- Until you spread your wings, you'll have no idea how far you can walk. |
134 days ago |
Hello Brad I to feel the same as everyone else I have used mdf and I,m feel it has it place don’t know if that’s in my shop with that said I to have had the same problem as you what I did to fix is drill out screw hole that is strip out and drill to 1/4 inch and glue in dowel and then pre drill and put screw in I have done this myself work good but not something you don’t what to do all time it a way save your project and you time, money to hope this helps |
134 days ago |
It is also important not to locate screws within about 2 inches from the end to avoid splitting the MDF. |
134 days ago |
Have you tried Spax screws? I bought some on a whim at Home Depot and have used them in both 1/2” and 3/4” MDF with great results and no pre-drilling. They have a special screw made just for MDF. As someone else has mentioned, though make sure you’re at least 1-2” from the ends. -- Premium firewood created daily. |
132 days ago |
If yoou need 7mmx50mm Confirmat screws at a really reasonable price that are not packaged in over the top priced retail packs…give us a call. |
132 days ago |
as stupid as this may sound. MDF has a “grain”, two kinds of grain,.......”face grain” which is the big 4’ x 8’ surface and “edge grain” which is the edge surface that runs around the perimetr of the 4’ x 8’ sheet. Screwing “into” face grain is almost always strong as an Oxen. Screwing into edge grain is almost always a disaster in waiting especially oif they are structural in nature as opposed to “pretty” aesthetics. To avoid “splitting” try joining it, instead of nails and screws, use biscuits, rabbets, dadoes, grooves, and glue, clamps…..no splits and strong like “Bull” I like confirmate screws as they have their place but I am certainly not convinced they work when applied into edge grains of MDF. Cheers |
127 days ago |
I glue everything first, overnigth an then screw the mdf nly to reinforce the joint. -- Tempus fugit...better work wood!!! |
| Forum | Topics |
Woodworking Skill Share
2913 |
3942 |
256 |
949 |
223 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2384 |
LumberJocks.com Site Feedback
524 |
